Abbozzo Pagina
This wiki page is a stub. Help us improve this page by adding information to it!
Wiki con Collaborazione Studenti
Un fantastico team di studenti del nostro programma educativo ha realizzato questo wiki.
Hand Vac will not Power On
The Charger Connection
If the hand vac does not power on then plug it up to its charger. Then, look for a charging light, and if it is not blue then look for debris in the connection ports. If that does not fix it, then the charger could be malfunctioned.
Batteries
Also, if the hand vac is not powering on and the connection is clear and the light is blue, then you could possibly have to replace the batteries.
Dust Escapes the Bowl
Seal
If there is dust escaping from the dust bowl you must open the container and take out the seal. Try cleaning the seal and the compartment to get a better seal so dust will not escape.
Filter
If you clean the seal and dust is still escaping, then you need to remove the filter and either clean or replace it.
Loss of Suction Power
Batteries
One problem coming up could be the batteries aren't taking a full charge. If this occurs, then see "Hand Vac will not Power On".
Motor
If you have replaced the batteries and the problem is still occurring, then you may have to replace the motor.
1 Commento
Unit powers on but then shuts off. We turn it on but it continues to shut off after 5-10 seconds.
tprendergast - Replica
