Wiki con Collaborazione Studenti
Un fantastico team di studenti del nostro programma educativo ha realizzato questo wiki.
Rice cooker will not turn on
The rice cooker's hot plate won't heat up at all even if the cook button is held down, and the problem isn't with the outlet.
Power cord is broken
If the device will not turn on, you may want to inspect the power cord for frays, gashes, or cuts. You will need to replace the power cord if it is damaged.
Internal circuitry is broken
Are you still not getting power to the device? This may be a problem with the internal circuitry and connections. You will want to check internally for faulty connections.
Rice cooker will not lock into on position
Pressing down the cook button doesn't lock the cooker with its button down, or it is not possible to try to press the cook button down because it is broken.
Button to turn on machine is broken
If the button on the rice cooker can't be pressed down to turn on the device, or is missing or broken, you'll need to replace it.
Spring that locks the hotplate down is broken
If the rice cooker continues to heat up after you take the rice bowl out, then you are going to need to replace the spring which turns off the heat.
Indicator light will not turn on
The light that indicates that the device is turned on won't light up when the device is on, but the device is heating properly.
Light is burnt out
If the rice cooker is heating properly, but the light isn't indicating whether the rice is cooked or kept warm, then the light bulbs are probably blown out and need to be replaced.
Light is not connected to the circuitry
Besides the light being burnt out, the light could be improperly connected to the circuitry. You can reconnect it if replacing the bulb doesn't work.
7 Commenti
Why won't my Brand New rice cooker light green come on
Catherine - Replica
My new rice cooker light green won't come on
Catherine - Replica
hi Team, light and switch everything is fine, but some how not heating the cooker….
deva k - Replica
i am not sure how to fix it.
deva k - Replica
La cuisson du riz débute et au bout de 5 à 10 minutes, s’arrête sans raison et on ne peut pas redémarrer le mode cuisson.
Céline Pagé - Replica
