Wiki con Collaborazione Studenti
Un fantastico team di studenti del nostro programma educativo ha realizzato questo wiki.
When you flip the on switch and your hair curler still does not power on, follow these steps to get your device running again.
Power Cord is Disconnected
The power cord going to the iron could be unplugged. Ensure that outlet is properly working and that power cord is secured inside the outlet
On Switch is Not Lighting Up
Ensure that light on switch is on or blinking, if not, maybe be caused by a faulty switch. Check out the link here to learn how to step b y step disassemble the device and remove the power switch and replace with a new one.
Power Cord is Broken
The power cord to the iron could be broken or shorted, visually inspect the outside of the cord and where the cord meets at the plug and ensure that it is intact and not obviously broken. If required, remove casing and inspect cable inside of device, to do that, check out the link here for step by step instructions.
Heating Element is not Functioning
Sometimes, it may appear that the iron is not getting power, however, it may be caused due to the heating element not functioning despite getting power. Check out the link here for step by step instructions to test if the heating element is receiving the power required.
0 Commenti
