Wiki con Collaborazione Studenti
Un fantastico team di studenti del nostro programma educativo ha realizzato questo wiki.
Acer Chromebook CB5-571-C5XU Troubleshooting
This troubleshooting page will help you resolve common issues with your Acer Chromebook CB5-571-C5XU.
Device Does Not Turn On
Power Indicator Flashing When Pressed
If the power indicator is flashing, this likely means the battery has fully discharged. Plug the laptop into a power outlet and confirm charging indicator is lighted. If it is not, confirm that the power outlet is working and the power supply cable is fully plugged in on both sides.
Charging Indicator Not Illuminating
If the charging indicator does not illuminate after the above step, unplug the laptop from both ends, then replug in the charger, laptop end first. Wait at least 30 minutes before trying to turn the laptop on again.
Touchpad Not Working Properly
Touchpad Reacts Too Quickly/Slowly
If the touchpad reacts too quickly or slowly, there are settings to adjust its sensitivity. Click on the “Settings” icon, and under the “Device” section, click “Touchpad”. The sliders under the title “Touchpad speed” will adjust the sensitivity of the touchpad.
Touchpad Not Responding To Input
If the touchpad will not respond to clicks, taps, or swipes, first make sure there is not dust or dirt on the touchpad. If it is clean, try pressing the ESC key several times, drum-rolling your fingers on the touchpad, and restarting the computer. If none of these options work, try resetting the computer.
Sound Is Distorted/Missing
Muted Sound
Check sound level to see if volume is set to zero or mute.
Other Outputs
Check if an external audio device, such as headphones or bluetooth speakers, are being used as the primary output for sound.
Keyboard Not Responding to Input
Volume or Brightness Keys Not Responding
If the volume or brightness keys are not working, this likely means those settings are either at their maximum or minimum. If not, it could be a wiring issue, and the keys might have to be replaced.
Backward or Forward Keys Not Responding
If the backward or forward keys are not responding, check to see if the backward and forward buttons on the web page are grayed-out. If so, there is not a page to go backward and/or forward to.
Additional Issues
If other keys on the keyboard are not responding, first try restarting the computer. If this does not work, trying using the keyboard as a guest. If this solves the issues, delete the account in which the keyboard did not work.
Camera/Webcam Not Displaying Image
First, try using the camera/webcam in a different application such as Hangouts. If this does not work, try restarting your laptop. If neither method works, contact the laptop’s manufacturer for more help.
0 Commenti
