Introduzione
If the display is damaged or malfunctioning, use this guide to replace it.
Cosa ti serve
Shut down the computer.
Disconnect the power and all external devices connected to the computer.
Disconnect the ribbon cables attaching the touch pad and keyboard to the system board (motherboard).
Using the Heavy-Duty Spudger lift up the plastic locks connecting the ribbon cable to the motherboard.
Use the blue plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
Using the Phillips 00 Screwdriver, remove 6 Phillips 2.0 x 4.6 mm screws from the perimeter of the battery.
(You don't NEED to remove this shielding as you can remove the board with it still there.)
Remove the adhesive strip.
Lift the shield away from the base of the laptop.
Disconnect the ribbon cables attached to the system board (motherboard).
Use the plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
Using the Phillips 00 Screw Driver, remove 5 Phillips 2.5 x 4.2 screws from the hinges from the laptop's base.
Follow these instructions in reverse order to reassemble your device.
Altre 5 persone hanno completato questa guida.
5 Commenti
You can. Fold the computer all the way over and go from there. The only advantage to opening the bottom would be to disconnect the battery: a highly recommended procedure.
A little extra pulling the mother board out. But I guess better safe then sorry. All in all this was a good guide!
REMEMBER if your new touch screen does not work (no touch screen) go into the device manager and uninstall i2c hid device. restart the laptop and the driver (and touch) should work again.
I was able to install a new screen. However, the “touch” does not work. I tried the uninstall i2c hid (and also HID- compliant touch screen) trick, but no luck. My guess is its my fault during install. Before I go diving back in for a loose connection, does anyone know which connection I should focus on?
