This manual will guide you through the steps involved in successfully removing the components of your Zune. This includes the hard drive, battery, screen, logic board, etc.
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Microsoft Zune 80, usa il nostro manuale di assistenza .
Using a metal spudger or Zune opening tool, remove the aluminum backing starting from the top. There are five clips on each side and two on the bottom.
WARNING: Be careful not to press the tools in too far because there are exposed cables right inside the edge of the device.
Unclick the black bar connecting the orange hard drive cable to the bottom of the hard drive.
Gently push towards the bottom of the device on the black bar until you hear a click sound. It is now disengaged from the hard drive.
If the cable does not come off easily, the black bar has not been un-clicked.
Now, gently pull the orange hard drive cable to remove it from the hard drive cable.
Lift the hard drive out of the device.
Remove the two T4 screws holding the metal brackets on both sides of the bottom of the device.
Remove the screws, brackets, and clips from the device. These are small pieces, so put them in a safe place.
The orange audio board cable is clipped in with a small black bar, like the hard drive cable.
Un-clip the bar by pushing upwards on the edge of the black bar towards the orange cable. You will hear it click when it disengages.
If the cable does not come off easily, the black bar has not been unclicked.
Flip the black bar to unclip the left side of the hard drive cable. You may now remove the hard drive cable.
Remove the battery from the device with the cables still connected.
Carefully lift up the logic board located at the base of the Zune.
Unclip the orange ribbon cable in the same manner as in the previous steps.
Remove the logic board from the Zune, leaving the black wire connected.
Carefully remove the wireless assembly that runs along the top and upper left edges of the Zune.
The assembly is lightly glued to the device. Use caution, as some force will be needed, but too much force will damage the board.
Remove the assembly and the battery together as one unit.
Incorpora questa guida
Scegli una dimensione e copia il codice qui sotto per incorporare questa guida come un piccolo widget sul tuo sito/forum.
Passo Singolo
Guida Completa
Piccolo - 600px
Medio - 800 px
Grande - 1200 px
Anteprima
