Introduzione
A quick and easy teardown/disassembly guide for the ZEN V Creative Media Player.
Questo smontaggio non è una guida di riparazione. Per riparare il tuo ZEN V Creative Media Player, usa il nostro manuale di assistenza.
Here we have Creative's ZEN V Media Player. The Navigator Stick The Play/Pause Button
  • Here we have Creative's ZEN V Media Player.
    • The Navigator Stick
    • The Play/Pause Button
    • The Back Button
    • The LCD
    • USB 2.0 Charging Port
    • Headphone Jack
    • Line In Jack
Aggiungi Commento
Start by taking a pointy metal spudger and insert it on the bottom edge of the player Slide it along, prying up until a gap forms Proceed to insert and slide the tool along the left and right side of the device, until the plastic piece with the buttons comes free.
  • Start by taking a pointy metal spudger and insert it on the bottom edge of the player
  • Slide it along, prying up until a gap forms
  • Proceed to insert and slide the tool along the left and right side of the device, until the plastic piece with the buttons comes free.
  • Half of the covering plastic should be off now
    • Gap between plastics
Aggiungi Commento
While doing the following steps note that this piece is glued on to the LCD. Do not apply too much force or shove your tool too far in Glue Bring your tool to the top edge of the player and insert it
  • While doing the following steps note that this piece is glued on to the LCD. Do not apply too much force or shove your tool too far in
    • Glue
  • Bring your tool to the top edge of the player and insert it
  • Insert it on the top edge and slide while prying up
    • The gap
  • Insert it on the two sides and pry until plastic comes loose
Aggiungi Commento
Be very gentle with the LCD in the next 2 steps! It is glued to the logic board with black stick pads. Do not break the cable/clip! Adhesive Pads
  • Be very gentle with the LCD in the next 2 steps! It is glued to the logic board with black stick pads. Do not break the cable/clip!
    • Adhesive Pads
    • Cable Clip
  • Insert flat end of plastic spudger on the bottom of the LCD. Pry gently upwards.
    • Bottom of LCD
  • Insert on the sides and continue to pry.
  • Finally insert on the top and pry.
    • Top of LCD
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Pull back LCD to bottom of player to expose cable/clip Remove orange ESD safe tape with spudger/fingernail Orange ESD safe tape
  • Pull back LCD to bottom of player to expose cable/clip
  • Remove orange ESD safe tape with spudger/fingernail
    • Orange ESD safe tape
  • Flip up the clip with flat end of spudger/fingernail
    • Clip is flipped up
  • Pull the LCD away from the player
Aggiungi Commento
Put down your spudger and pick up a Phillips #000 Screwdriver Remove the two screws on the logic board Screws
  • Put down your spudger and pick up a Phillips #000 Screwdriver
  • Remove the two screws on the logic board
    • Screws
  • Remove Volume control button by pulling it up off the board
    • Volume control button
  • Pull up board from bottom of player
  • Gently wiggle the logic board out of the casing. Be careful because it is connected to a battery underneath it
    • Battery
Aggiungi Commento
Insert spudger under the top of the battery and pry Top half of battery There is an adhesive pad under the battery
  • Insert spudger under the top of the battery and pry
    • Top half of battery
  • There is an adhesive pad under the battery
  • Battery should now be free
  • Remove battery from case and set aside connected to the logic board
Aggiungi Commento
Battery may now be removed from logic board with a soldering iron
  • Battery may now be removed from logic board with a soldering iron
  • Heat up the contacts and pull away wires
    • Contacts
Aggiungi Commento
These all are various components that can be removed with a soldering iron USB 2.0 Port has 4 pads and 5 pins attaching it to the logic board
  • These all are various components that can be removed with a soldering iron
    • USB 2.0 Port has 4 pads and 5 pins attaching it to the logic board
    • Various Switches- 4 pads each. From the (Bottom left), Volume up, Volume Down, Mute?, (Top Left), Power on/Hold, Reset
    • Line In Jack 4 pads
    • Headphone Jack 4 pads
    • Play/Pause Button 2 pads and Back Button 2 pads
    • LCD connector and Navigtor button
Aggiungi Commento
All the innards of the ZEN V Media Player
  • All the innards of the ZEN V Media Player
    • Button Plastic- Removed in Step 2
    • LCD Plastic- Removed in Step 3
    • Orange ESD Safe tape and LCD Screen- Removed in Step 5
    • Screws and Volume Button- Removed in Step 6
    • Back Plastic Case and Logic Board- Removed in Step 7
    • Battery Removed in Step 8
It's so nice to see such a broad spectrum of color in a teardown.
Nat Welch - Replica
Sure! I believe the Color/Labeling Feature is one of the most useful tools in your teardown creator. I intend to use it well in all my future teardowns.
Liam Speirs - Replica
Liam Speirs
Membro da: 08/11/2009
322 Reputazione
2 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 22
Tutti i Tempi: 12,591
