Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Suzuki FA50 Moped, usa il nostro manuale di assistenza.
  1. Suzuki FA50 Moped Throttle Cable Teardown, Suzuki FA50 Moped Throttle Cable Teardown: passo 1, immagine 1 di 1
    • Here is the assembled throttle cable. It seems to be assembled correctly, but certainly does not function properly.
  2. Suzuki FA50 Moped Throttle Cable Teardown: passo 2, immagine 1 di 2 Suzuki FA50 Moped Throttle Cable Teardown: passo 2, immagine 2 di 2
    • The throttle parts.
    • The only logical way for me to assemble these parts were:
    • Insert needle into gold-colored cylinder.
    • Insert retaining clip on top of needle.
    • Then compress and insert the spring (see following steps on how the spring was inserted).
  3. Suzuki FA50 Moped Throttle Cable Teardown: passo 3, immagine 1 di 1
    • The throttle cable without any parts.
    • The round, gray top screws into the carburetor.
  4. Suzuki FA50 Moped Throttle Cable Teardown: passo 4, immagine 1 di 1
    • To assemble the throttle cable:
    • I first use a pair of needle-nose pliers to compress the spring as much as I can.
    • This allows me to insert the throttle cable into the gold-colored cylinder without having to meddle with the spring too much.
  5. Suzuki FA50 Moped Throttle Cable Teardown: passo 5, immagine 1 di 2 Suzuki FA50 Moped Throttle Cable Teardown: passo 5, immagine 2 di 2
    • I attach the throttle cable to the bottom of the gold cylinder and then route it through the cylinder's side slot.
    • The alternate view (picture 2) shows how everything looks internally.
    • After the throttle cable is in place, I let go of the spring into the cylinder.
  6. Suzuki FA50 Moped Throttle Cable Teardown: passo 6, immagine 1 di 2 Suzuki FA50 Moped Throttle Cable Teardown: passo 6, immagine 2 di 2
    • I'm simulating screwing on the throttle to the carburetor by compressing the gold cylinder against the gray cap. As you can see, the spring compresses, and the throttle cable pops outward.
    • When I twist the moped's throttle, the throttle cable goes inwards. I believe this is the desired action for the cable.
    • There are two problems, however:
    • Nothing pushes the throttle cable back out when I release the moped's throttle.
    • The throttle needle does not move, but to my understanding it should go upward when I apply the throttle.
    • Please check out my Answers question if you can help me solve this problem! Thanks a lot!
2 Commenti
which way does you set the throttle when you put it in
ladell - Replica
It appears to be correctly assembled however the cable isn't bottomed out on the cup to allow for free movement, I think you may have put a flat spot in to the cable itself that's not allowing the cup to bottom out on it and giving you the return movement.
Ken James - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 45
Tutti i Tempi: 12,873
