Strumenti necessari in questo Smontaggio
Introduzione
This guide will walk you through the steps to completely disassemble a Sprint Airave.
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Sprint Airave SCS-26UC2, usa il nostro manuale di assistenza.
Remove the external antenna, GPS cover, and GPS module. Remove the external antenna, GPS cover, and GPS module. Remove the external antenna, GPS cover, and GPS module.
  • Remove the external antenna, GPS cover, and GPS module.
Aggiungi Commento
Use a pry tool to remove the white outer cover. Pry towards the front of the device. Continue prying down the length of the cover until it pops off. Use a pry tool to remove the white outer cover. Pry towards the front of the device. Continue prying down the length of the cover until it pops off. Use a pry tool to remove the white outer cover. Pry towards the front of the device. Continue prying down the length of the cover until it pops off.
  • Use a pry tool to remove the white outer cover. Pry towards the front of the device. Continue prying down the length of the cover until it pops off.
Aggiungi Commento
Locate and remove the four Phillips screws
  • Locate and remove the four Phillips screws
Aggiungi Commento
With the cover removed you now have access to the circuit board.
  • With the cover removed you now have access to the circuit board.
Aggiungi Commento
Using an 8mm socket you can remove the antenna pigtail.
  • Using an 8mm socket you can remove the antenna pigtail.
Aggiungi Commento
Release the clip indicate to remove the circuit board.
  • Release the clip indicate to remove the circuit board.
Aggiungi Commento
Here is the circuit board fully removed. Here is the circuit board fully removed.
  • Here is the circuit board fully removed.
Aggiungi Commento
Erik Leonard
Membro da: 11/06/2011
164 Reputazione
1 Guida realizzata
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,988
