Introduzione
First attempt at a tear down of Seagates 3TB External Drive.
Cosa ti serve
Start at the plain end (the opposite side from the power jack) with the spudger. Carefully pry slightly up and away.
Once you have the end opened up, use the credit card to hold it open.
When you have the entire end separated, carefully pry the sides out and away along the adjoining two sides, working your way towards the end with the power jack. Save that end for last, it should lift away when you're done with the other sides.
3 Commenti
Does anyone know what to do if the Data port does not work ?
Thanks... I probably broke every clip in the process, but I finally got it apart... Tested the drive in another external USB case and still can't see the drive, so my hope that it was the case circuitry that was bad was crushed... 3TB paperweight... Thanks Seagate :(
