Strumenti necessari in questo Smontaggio
Introduzione
The Teardown is pretty much the same as other Samsung Slider phones
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Samsung Intensity, usa il nostro manuale di assistenza.
Remove the back cover and battery
  • Remove the back cover and battery
Aggiungi Commento
Remove the 8 screw that hold the back cover down.
  • Remove the 8 screw that hold the back cover down.
  • Carefully pry back piece off
  • Start at the bottom and work toward the top.
Aggiungi Commento
Use the ipod opening tool to disconnect the Connector
  • Use the ipod opening tool to disconnect the Connector
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Carefully remove the main board Make sure to not tear the microphone cable, pry it from the phone carefully
  • Carefully remove the main board
    • Make sure to not tear the microphone cable, pry it from the phone carefully
Aggiungi Commento
Remove the 6 screws Pry to ribbon cable assembly loose from the slider
  • Remove the 6 screws
  • Pry to ribbon cable assembly loose from the slider
  • Its glued on the left and right side
Aggiungi Commento
Remove the 4 screw the holds the slider to the phone assembly
  • Remove the 4 screw the holds the slider to the phone assembly
  • one of the screws will be behind the hinge
  • Carefully pry slider assembly loose from display assembly
Aggiungi Commento
Remove the tape and pop the connectors and pull all the ribbon cables loose Carefully pry the speaker loose from the case. Carefully pry the speaker loose from the case.
  • Remove the tape and pop the connectors and pull all the ribbon cables loose
  • Carefully pry the speaker loose from the case.
Aggiungi Commento
Carefully work the keyboard loose from the display assembly
  • Carefully work the keyboard loose from the display assembly
  • There are a couple fragile clips that hold it in place
Aggiungi Commento
LCD comes out pretty easily Pry it from the bottom and work up the sides to release it if stuck
  • LCD comes out pretty easily
  • Pry it from the bottom and work up the sides to release it if stuck
  • The glass can be removed with a little heat from a heat gun or blow dryer
  • Pry it out from the outside edges working around carefully
Aggiungi Commento
David
Membro da: 10/08/2011
110 Reputazione
1 Guida realizzata
West Georgia Technology Membro di West Georgia Technology
Business
1 Membro
1 Guida realizzata
This was so helpful! How can I show my gratitude to you for these helpful instructions?
teh_pwnerer22 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 19
Tutti i Tempi: 3,633
