Strumenti necessari in questo Smontaggio
Introduzione
Here we are with a broken, water damaged/bricked Samsung Galaxy S.
I've taken it apart before, so why not now.
Lets go!
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Samsung Galaxy S, usa il nostro manuale di assistenza.
The phone itself!
  • The phone itself!
  • Notice the bad lighting, dirty phone etc. just proves how hi-tec i am.
Aggiungi Commento
Removing the boring stuff. Back cover, battery etc. Removing the boring stuff. Back cover, battery etc. Removing the boring stuff. Back cover, battery etc.
  • Removing the boring stuff. Back cover, battery etc.
Aggiungi Commento
The battery! It shows 1500mAh, decent.
  • The battery!
  • It shows 1500mAh, decent.
  • also the manufacturing date is shown.
  • I added a piece of sticky tack, to cover up the IMEI code, again showing how hi-tec i am!
Aggiungi Commento
This is the point of no return when it comes to warranty. But that's okay, i'm using this phone for spares anyways.
  • This is the point of no return when it comes to warranty.
  • But that's okay, i'm using this phone for spares anyways.
  • Sticky tack
  • Screws, 7 to be exact!
Aggiungi Commento
Here comes the first tricky part. it's easiest to start right under the volume button, and work your way from there. Be extremely careful if you are using metal tools like i am. it will easily damage components if you accidentally jam it in.
  • Here comes the first tricky part. it's easiest to start right under the volume button, and work your way from there.
  • Be extremely careful if you are using metal tools like i am. it will easily damage components if you accidentally jam it in.
  • And it's off!
Aggiungi Commento
Lets see the innards of this thing. The back camera. And the front facing camera
  • Lets see the innards of this thing.
  • The back camera.
  • And the front facing camera
  • The speaker, actually quite large.
  • Water detector on the plastic cover, as you can see, this is a water damaged phone. normally you would see a purple pattern.
  • Contacts, probably for antennas.
Aggiungi Commento
Better close ups of the components. Vibration motor
  • Better close ups of the components.
  • Vibration motor
Aggiungi Commento
Taking off the speaker. Remember to lift the tab on me! And it's off!
  • Taking off the speaker.
  • Remember to lift the tab on me!
  • And it's off!
Aggiungi Commento
Now for the camera! Both the rear and front camera are a single component. Lift the connector in picture 2 carefully! lots of components under it.
  • Now for the camera!
  • Both the rear and front camera are a single component.
  • Lift the connector in picture 2 carefully! lots of components under it.
Aggiungi Commento
Now for the motherboard! Detach all (4) of these to get the motherboard out.
  • Now for the motherboard!
  • Detach all (4) of these to get the motherboard out.
  • Done! (do not try to remove yet)
Aggiungi Commento
Now detach the power button, its held down by a little bit of glue, not a big deal. Lift it carefully, making sure no connectors are stuck on. Especially the one marked red.
  • Now detach the power button, its held down by a little bit of glue, not a big deal.
  • Lift it carefully, making sure no connectors are stuck on. Especially the one marked red.
Aggiungi Commento
Front/back Flash memory.
  • Front/back
  • Flash memory.
  • CPU running at 1Ghz, but can be overclocked.
  • Volume buttons.
  • Ill add more specific specs when i get around to it.
Aggiungi Commento
Removing the cable for sim/sd card slot.. And it's off. Bad white balance, sorry!
  • Removing the cable for sim/sd card slot..
  • And it's off.
  • Bad white balance, sorry!
Aggiungi Commento
The simcard/sd card slot. And the stuff underneath.
  • The simcard/sd card slot.
  • And the stuff underneath.
Aggiungi Commento
Now for the metal Shielding on the back! again, more specs coming (hopefully) soon. Now for the metal Shielding on the back! again, more specs coming (hopefully) soon. Now for the metal Shielding on the back! again, more specs coming (hopefully) soon.
  • Now for the metal Shielding on the back! again, more specs coming (hopefully) soon.
Aggiungi Commento
Parts parts parts!
  • Parts parts parts!
  • And a bad white balance..
Aggiungi Commento
Now for the component that holds the headphone jack, earpiece and both proximity and light sensor. There is a cool app "androsensor" that lets you access all the sensors in your phone! This thing quite literally just pulls off. you can remove it without any special tools!
  • Now for the component that holds the headphone jack, earpiece and both proximity and light sensor.
  • There is a cool app "androsensor" that lets you access all the sensors in your phone!
  • This thing quite literally just pulls off. you can remove it without any special tools!
  • Be careful not to tug on the cables too hard! there is some glue, but it peels right off.
Aggiungi Commento
Now for the bottom portion, including the Mic, vibrating engine and the antenna board. I couldn't get it off completely, but i can give you a good picture of what it looks, lets see..
  • Now for the bottom portion, including the Mic, vibrating engine and the antenna board.
  • I couldn't get it off completely, but i can give you a good picture of what it looks, lets see..
  • We seem to be connected together!
Aggiungi Commento
Disconnect, unplug, take off.. Disconnect, unplug, take off.. Disconnect, unplug, take off..
  • Disconnect, unplug, take off..
Aggiungi Commento
Be extremely careful when taking off these little boards, they're on tight! and they like to bend around. Be extremely careful when taking off these little boards, they're on tight! and they like to bend around. Be extremely careful when taking off these little boards, they're on tight! and they like to bend around.
  • Be extremely careful when taking off these little boards, they're on tight! and they like to bend around.
Aggiungi Commento
see that? the AMOLED display is actually transparent! Can't go farther than this without a heat gun that I don't have. I tried removing the bezel, but with no luck. That's about it! Thank you for reading, and please give me feedback!
  • see that? the AMOLED display is actually transparent!
  • Can't go farther than this without a heat gun that I don't have. I tried removing the bezel, but with no luck.
  • That's about it! Thank you for reading, and please give me feedback!
  • This is my first teardown, and pictures were taken with a functional Galaxy s phone.
Aggiungi Commento
valtteri
Membro da: 18/11/2011
803 Reputazione
2 Guide realizzate
I would like to replace just the front lens of the phone , cuz the old one got cracked, can you do a tutorial on that , do I have to teardown the hole phone to replace the front panel without the digitizer.
Samsung galaxy s1 i900
Kasavin Drago - Replica
You have come a long way from this tear down to the ones done now!
Shreyas Bharadwaj - Replica
thank you. my son broke his Galaxy S sim card pins(third smart phone in five months!!!) and I am hoping to repair it myself with the help of your fix-it.Will let you know if I succeed.Margaret, April 2014.
margaret - Replica
Hi I dropped my phone and it the glasses shattered and totally shutdown when dead on me. Wondering any hope for repairs?
Nabikaly - Replica
What is the part number of the Bluetooth Chip here?Manufacturer?
Raul Piper - Replica
My phone has problem about on off
When it plug in to charger battery shows charging but it didn't on please tell the solution
Rohit Shinde - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 41
Ultimi 30 Giorni: 151
Tutti i Tempi: 58,730
