Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Samsung GT-E2120, usa il nostro manuale di assistenza.
  1. Samsung GT-E2120 Teardown, Samsung GT-E2120 Teardown: passo 1, immagine 1 di 1
    • Before you begin it's always good to ground yourself to eliminate the risk for shock.
  2. Samsung GT-E2120 Teardown: passo 2, immagine 1 di 2 Samsung GT-E2120 Teardown: passo 2, immagine 2 di 2
    • Using your thumb, press down on the back of the device in a downward motion to open the back cover.
    • Remove the battery along with the sim card and Micro-SD card.
    • This phone can take up to a 2GB Micro-SD card and is great for storing music. It even has a FM radio!
  3. Samsung GT-E2120 Teardown: passo 3, immagine 1 di 2 Samsung GT-E2120 Teardown: passo 3, immagine 2 di 2
    • Next, using a Philips screwdriver, remove the five screws from the back of the device.
  4. Samsung GT-E2120 Teardown: passo 4, immagine 1 di 3 Samsung GT-E2120 Teardown: passo 4, immagine 2 di 3 Samsung GT-E2120 Teardown: passo 4, immagine 3 di 3
    • For this step a matal spudger is used to release the clips along the bottom, top, and sides of the phone.
    • These clips can be found at the points marked in red.
    • Working from the top down, gently prying at the case the clips are easily dislodged.
  5. Samsung GT-E2120 Teardown: passo 5, immagine 1 di 2 Samsung GT-E2120 Teardown: passo 5, immagine 2 di 2
    • When the bottom of the phone is reached it is a bit harder to pull the bottom clips off.
    • This can be made a tad easier by using the pointed end of the spudger to get in and under the case.
    • Once the case is lifted up slightly, you can get enough purchase under the clip and lift it off.
    • Be careful so you dont damage the motherboard!
  6. Samsung GT-E2120 Teardown: passo 6, immagine 1 di 1
    • This images shows the two halves separated.
    • The camera located in the blue square is a VGA 640X480 resolution color camera.
  7. Samsung GT-E2120 Teardown: passo 7, immagine 1 di 2 Samsung GT-E2120 Teardown: passo 7, immagine 2 di 2
    • The microphone is carefully lifted from its bracket, and the motherboard is carefully removed.
  8. Samsung GT-E2120 Teardown: passo 8, immagine 1 di 1
    • Then the keyboard is simply pushed out.
    • The Phone includes a 65K CSTN color screen with a 128X128 resolution.
Michael C
Membro da: 01/09/11
410 Reputazione
1 Guida realizzata
OPEN Membro di OPEN
Community
82 Membri
25 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 14
Tutti i Tempi: 14,013
