Questo smontaggio non è una guida di riparazione. Per riparare il tuo Rubik's Cube, usa il nostro manuale di assistenza.
Turn the top row so that each corner is roughly halfway between the sides Push the pieces up until they pop out of the cube, then, slide the rest out Repeat this process until you clear the level
  • Turn the top row so that each corner is roughly halfway between the sides
  • Push the pieces up until they pop out of the cube, then, slide the rest out
  • Repeat this process until you clear the level
Aggiungi Commento
You should be able to just directly pull out the rest of the blocks, like so And there you have it!
  • You should be able to just directly pull out the rest of the blocks, like so
  • And there you have it!
  • You'll have the center piece, with the six centers of the six sides, the turning mechanism
Aggiungi Commento
To reassemble, snap all the pieces back into place, and try not to rotate the faces. It helps to start with the middle pieces first
  • To reassemble, snap all the pieces back into place, and try not to rotate the faces.
  • It helps to start with the middle pieces first
  • Don't be afraid to use force!
  • Once you have the middle pieces in it's pretty simple to just push in the corner pieces
  • Again- don't be afraid to use force!
Aggiungi Commento
rab777hp
Membro da: 17/11/2009
20.113 Reputazione
7 Guide realizzate
OPEN Membro di OPEN
Community
73 Membri
14 Guide realizzate
I hated this thing. I disassembled mine with a .22 hollow point at 100 yards. Yes, It felt great!
mpias - Replica
lol don’t blame you, can’t stand the thing
Luke Legg -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 42
Ultimi 30 Giorni: 187
Tutti i Tempi: 17,346
