Strumenti necessari in questo Smontaggio
Introduzione
I've found a vacuum in my utility room. Since I almost never use it, I thought it was a good idea to see how it works... So let's go!!
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Rowenta AC6221, usa il nostro manuale di assistenza.
The 4.8 Rowenta vacuum can be used  for a variety of purposes. It is charged through its pedestal. The power of the pedestal is: Input: 230V - 50 Hz - 7W (AC)
  • The 4.8 Rowenta vacuum can be used for a variety of purposes.
  • It is charged through its pedestal. The power of the pedestal is:
    • Input: 230V - 50 Hz - 7W (AC)
    • Output: 7.5V - 300 mA (DC)
Aggiungi Commento
This vacuum has several parts: The tip The reservoir which holds the dust and debris
  • This vacuum has several parts:
    • The tip
    • The reservoir which holds the dust and debris
    • The engine (4.8V)
    • The pedestal
    • The power supply
  • From top to bottom, the reservoir contains 3 parts: the housing, container, and filter.
Aggiungi Commento
Remove the two outer Philips #00 screws from the bottom of the engine. The back of the circuit board will now be visible. The back of the circuit board will now be visible.
  • Remove the two outer Philips #00 screws from the bottom of the engine.
  • The back of the circuit board will now be visible.
Aggiungi Commento
Remove the two inner screws. Insert a flat screwdriver between the cover and the base of the engine and remove the cover. Insert a flat screwdriver between the cover and the base of the engine and remove the cover.
  • Remove the two inner screws.
  • Insert a flat screwdriver between the cover and the base of the engine and remove the cover.
Aggiungi Commento
  • The wires of the vacuum are now visible.
Aggiungi Commento
The wires of the vacuum are now visible. The wires connect the charger light, switch,engine, and power wires.
  • The wires connect the charger light, switch,engine, and power wires.
  • The green box labels the engine.
  • The orange box labels one of the four batteries (4*1.2V)
Aggiungi Commento
The top of the circuit board contains components including capacitors, resistors, wires, and a chip. The bottom side shows the tracks that connect the components.
  • The top of the circuit board contains components including capacitors, resistors, wires, and a chip.
  • The bottom side shows the tracks that connect the components.
Aggiungi Commento
Remove the screw securing the handle with a screwdriver. Open the handle to see the inside using the flat screwdriver.
  • Remove the screw securing the handle with a screwdriver.
  • Open the handle to see the inside using the flat screwdriver.
    • Warning: The handle is difficult to open
    • Warning: In this procedure, the handle was not opened to keep the vacuum intact.
Aggiungi Commento
This is the pedestal that will be torn down.
  • This is the pedestal that will be torn down.
Aggiungi Commento
At the bottom of the pedestal, remove the 4 rubber pieces. Note: This step provides access to 4 Philips screws. Remove screws using a screwdriver.
  • At the bottom of the pedestal, remove the 4 rubber pieces.
    • Note: This step provides access to 4 Philips screws.
  • Remove screws using a screwdriver.
Aggiungi Commento
Lift the plastic piece carefully from the bottom of the pedestal.
  • Lift the plastic piece carefully from the bottom of the pedestal.
Aggiungi Commento
Inside the pedestal, the power cable separates into 2 wires. Each wire is connected to a conductive piece.
  • Inside the pedestal, the power cable separates into 2 wires. Each wire is connected to a conductive piece.
  • This completes the vacum cleaner teardown
Aggiungi Commento
Bob
Membro da: 17/04/2010
686 Reputazione
3 Guide realizzate
This could use some discussion of how to replace the rechargeable batteries used in portable vacuum cleaners.
Wayne Seltzer - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 28
Tutti i Tempi: 5,566
