Strumenti necessari in questo Smontaggio
Introduzione
This is a teardown of the RIM Blackberry.
Questo smontaggio non è una guida di riparazione. Per riparare il tuo BlackBerry 7290, usa il nostro manuale di assistenza.
With your index finger, press down on the lock button to unlock the battery cover. Slide the battery cover down towards you to reveal the battery. Slide the battery cover down towards you to reveal the battery.
  • With your index finger, press down on the lock button to unlock the battery cover.
  • Slide the battery cover down towards you to reveal the battery.
Aggiungi Commento
Use your index finger to lift and remove the battery from the phone. Use your index finger to lift and remove the battery from the phone. Use your index finger to lift and remove the battery from the phone.
  • Use your index finger to lift and remove the battery from the phone.
Aggiungi Commento
Slide the SIM card holder to the left to unlock the SIM card.
  • Slide the SIM card holder to the left to unlock the SIM card.
Aggiungi Commento
Lift the SIM card holder up. Gently remove the SIM card from the SIM card holder.
  • Lift the SIM card holder up.
  • Gently remove the SIM card from the SIM card holder.
Aggiungi Commento
Remove the four top screws using a T-6 torx screwdriver.
  • Remove the four top screws using a T-6 torx screwdriver.
  • The top four screws are .413 inches.
Aggiungi Commento
Remove the two bottom screws using a T-6 torx screwdriver. The bottom two screws are .2 inches in length.
  • Remove the two bottom screws using a T-6 torx screwdriver.
  • The bottom two screws are .2 inches in length.
  • The second picture displays the device after the six screws have been removed.
Aggiungi Commento
Use the plastic opening tool to apply pressure on the two clips that are located at the bottom of the phone.
  • Use the plastic opening tool to apply pressure on the two clips that are located at the bottom of the phone.
Aggiungi Commento
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
With both of the bottom clips unhooked, lift the bottom portion of the phone and slide it upwards (towards your fingers) to detach the back cover from the front cover. With both of the bottom clips unhooked, lift the bottom portion of the phone and slide it upwards (towards your fingers) to detach the back cover from the front cover. With both of the bottom clips unhooked, lift the bottom portion of the phone and slide it upwards (towards your fingers) to detach the back cover from the front cover.
  • With both of the bottom clips unhooked, lift the bottom portion of the phone and slide it upwards (towards your fingers) to detach the back cover from the front cover.
Aggiungi Commento
Using a T-6 screwdriver, remove the screw located on top of the phone. After the screw has been removed, carefully lift the side button brace to reveal the side button.
  • Using a T-6 screwdriver, remove the screw located on top of the phone.
  • After the screw has been removed, carefully lift the side button brace to reveal the side button.
Aggiungi Commento
To remove the logic board mounting plate, start by loosening one side of the phone.
  • To remove the logic board mounting plate, start by loosening one side of the phone.
Aggiungi Commento
With one side loosened, simply lift the logic board mounting plate off of the phone's front cover.
  • With one side loosened, simply lift the logic board mounting plate off of the phone's front cover.
Aggiungi Commento
Turn the logic board mounting plate over to reveal the LCD display.
  • Turn the logic board mounting plate over to reveal the LCD display.
Aggiungi Commento
Peel off the rubber keypad buttons from the face plate. Peel off the rubber keypad buttons from the face plate.
  • Peel off the rubber keypad buttons from the face plate.
Aggiungi Commento
Use a plastic opening tool to unhook the LCD display from the logic board mounting plate.
  • Use a plastic opening tool to unhook the LCD display from the logic board mounting plate.
Aggiungi Commento
With the clip unhooked, gently pull off the LCD display from the phone. With the clip unhooked, gently pull off the LCD display from the phone.
  • With the clip unhooked, gently pull off the LCD display from the phone.
Aggiungi Commento
Remove the the three screws that are highlighted in red using a T6 torx screwdriver. The screw is .2 inches in length.
  • Remove the the three screws that are highlighted in red using a T6 torx screwdriver.
  • The screw is .2 inches in length.
Aggiungi Commento
Remove the screw using a T6 torx screwdriver
  • Remove the screw using a T6 torx screwdriver
Aggiungi Commento
Separate the logic board mounting plate from the logic board. Separate the logic board mounting plate from the logic board.
  • Separate the logic board mounting plate from the logic board.
Aggiungi Commento
These are all the components of the phone. These are all the components of the phone.
  • These are all the components of the phone.
Aggiungi Commento
kenny34
Membro da: 28/10/2009
69 Reputazione
1 Guida realizzata
Cal Poly, Team 19-6, Maness Fall 2009 Membro di Cal Poly, Team 19-6, Maness Fall 2009
CPSU-MANESS-F09S19G6
5 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 5,894
