Strumenti necessari in questo Smontaggio
Introduzione
The Powermac G3, apple's G3 Powerhouse. This computer Introduced the design that stuck until the powermac G5, but this computer started the "Handle's" Trend, every powermac G3, G4, G5, and Mac Pro now has handles. This computer boasted a 350Mhz, 400Mhz, and 450Mhz PowerPC G3 CPU. This cpu is incredibly easy to overclock, due to it's "clock-config" jumper convienlently located next to the CPU(though i don't encourage overclocking). This computer had blue plastic, resembelent of the iMac G3's and the iBook G3 Clamshells. It would have been great if Apple had made this is other colors, like the imac, a lime green Powermac G3 would rock!
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Power Macintosh G3 Blue and White, usa il nostro manuale di assistenza.
The Powermac G3 Blue And White The Powermac G3 Blue And White The Powermac G3 Blue And White
  • The Powermac G3 Blue And White
Aggiungi Commento
Start By Disconnecting the computer, and lifting the tab on the side of the computer, and lowering the side panel. Start By Disconnecting the computer, and lifting the tab on the side of the computer, and lowering the side panel. Start By Disconnecting the computer, and lifting the tab on the side of the computer, and lowering the side panel.
  • Start By Disconnecting the computer, and lifting the tab on the side of the computer, and lowering the side panel.
Aggiungi Commento
RAM The PowerMac G3 B&W supports up to 1GB of PC100 RAM.
  • RAM
  • The PowerMac G3 B&W supports up to 1GB of PC100 RAM.
  • It has 4 RAM slots for an optimal configuration of 4x 256MB DIMM's.
the b&w g3 supports up to 1gb pc100 ram.
khlae - Replica
Quote from khlae:
Khale's right- my G3 currently has 1GB.
Josh Calvetti - Replica
Removing The CPU Start by using a flathead to gently pry off the clip, remember you have to put it back on again! Then, remove the heatsink.
  • Removing The CPU
  • Start by using a flathead to gently pry off the clip, remember you have to put it back on again!
  • Then, remove the heatsink.
  • This reveals the Motorola PowerPC G3 CPU, this is the 400Mhz Model.
Aggiungi Commento
Then, lift the metal retaining lever. Then, lift the CPU out of it's socket. This is the Motorola MPC106 PCI bridge and memory controller.
  • Then, lift the metal retaining lever.
  • Then, lift the CPU out of it's socket.
  • This is the Motorola MPC106 PCI bridge and memory controller.
Aggiungi Commento
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
The CPU: A Motorola XPC750MIP400CM (400Mhz PowerPC 750/G3) With 1Mb Of Level 2 Cache. This is another one of those unique apple connectors, it it is a 288 pin keyed PGA socket.
  • The CPU: A Motorola XPC750MIP400CM (400Mhz PowerPC 750/G3) With 1Mb Of Level 2 Cache.
  • This is another one of those unique apple connectors, it it is a 288 pin keyed PGA socket.
Aggiungi Commento
Graphics Card: The Powermac G3 Came Standard With A 16MB ATI 3D Rage PCI Mac Edition Card, there are only a few available upgrade cards.
  • Graphics Card:
  • The Powermac G3 Came Standard With A 16MB ATI 3D Rage PCI Mac Edition Card, there are only a few available upgrade cards.
  • Start By Removing this Screw.
  • Once that's done, pull the card out.
  • Sorry Guys, Regular PCI Cards Won't work here, only Mac Edition PCI-Compatible Cards, and this card won't work in a PC, Also, graphics cards only work in the first slot, the other 4 PCI Slots won't support graphics cards.
Aggiungi Commento
Firewire Module: Unplug the power cable from the logic board. Then close the case and remove this screw.
  • Firewire Module:
  • Unplug the power cable from the logic board.
  • Then close the case and remove this screw.
  • Then open it again.
Aggiungi Commento
Then remove this screw too. Then lift the module out, there is a connector underneath it, to be careful while doing this. Then we can move on.
  • Then remove this screw too.
  • Then lift the module out, there is a connector underneath it, to be careful while doing this.
  • Then we can move on.
Aggiungi Commento
Removing the Optical Drive/ZIP Drive Caddy: Start by pushing in these tabs, and pulling the blue drive bezel out. Start by pushing in these tabs, and pulling the blue drive bezel out.
  • Removing the Optical Drive/ZIP Drive Caddy:
  • Start by pushing in these tabs, and pulling the blue drive bezel out.
Aggiungi Commento
This will reveal 2 phillips screws. Remove them. Then push the back of the cage out the front of the case far enough to remove the ribbon and power cables, than slide the cage completly out, and set it aside.
  • This will reveal 2 phillips screws.
  • Remove them.
  • Then push the back of the cage out the front of the case far enough to remove the ribbon and power cables, than slide the cage completly out, and set it aside.
Aggiungi Commento
Removing the drive cage: Removing the drive cage:
  • Removing the drive cage:
Aggiungi Commento
Removing the power supply Disconnect the power connector from the logic board (this looks alot like a standard ATX connector. The lone difference is that the wire which supplies -5V on an ATX supply [pin 18] becomes a ground wire in the B&W G3.  If you just plug in an ATX supply without any modifications, you'll short out its -5V output. ) There is a 4-Pin Cable connected to the front panel box, remove it.
  • Removing the power supply
  • Disconnect the power connector from the logic board (this looks alot like a standard ATX connector. The lone difference is that the wire which supplies -5V on an ATX supply [pin 18] becomes a ground wire in the B&W G3. If you just plug in an ATX supply without any modifications, you'll short out its -5V output. )
  • There is a 4-Pin Cable connected to the front panel box, remove it.
  • Disconnect the internal fan cable.
  • The Fan Connector
  • Then Route all of the cables up through the case to the level of the power supply.
Aggiungi Commento
Remove these phillips screws.
  • Remove these phillips screws.
  • Now, you can slide the power supply towards you, and remove it.
  • Sorry, but my camera battery died, I will post photos on how to remove the logic board after I take them
Sorry, but you didn’t mention to remove 2 hex screws from the back of the case on both sides of the power connectors!
Jim Wallace - Replica
  • Also remove all 3 hex screws from the rear of the case located around the power connectors. Only then, will the PS "just slide out."
Aggiungi Commento
Chris Green
Membro da: 11/10/2009
30.934 Reputazione
46 Guide realizzate
Master Techs Membro di Master Techs
Community
273 Membri
699 Guide realizzate
I dub thee Chris Green, The Teardown Machine. Good work!
Miroslav Djuric - Replica
The CPU socket looks identical to Intel's socket 478.
Honam1021 - Replica
Actually, I have to call you on your comment about the PCI slots. I used to run a dual monitor setup on my B&W G3. I had an ATI Xclaim VR 128 installed in the second slot, giving me a second graphics card, with a TV tuner/AV input. It worked perfectly. The Tuner's software never made the transition to Mac OS X, sadly, so i had to boot into OS 9 any time I wanted to do recording, but it most definitely worked.
richfiles - Replica
Yep, the pci slots will absolutely run graphics cards. If they didn't they wouldn't be pci slots. I also ran graphics cards off of them. However, they run like crud compared to the 66mhz slot, since they are shared and 33mhz. You can also run standard PC graphics cards, as long as there is a mac compatible rom that you can flash onto it. Reflashed cards used to sell on ebay for real good prices.
khlae -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 46
Ultimi 30 Giorni: 139
Tutti i Tempi: 30,999
