Strumenti necessari in questo Smontaggio
Introduzione
In this tutorial we will show you a breakdown of the Panazonic EB TX320. By using this guide, a user will be able to properly take apart their phone and replace any broken components.
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Panasonic EB TX320ASW, usa il nostro manuale di assistenza.
To remove the faceplate, pry the top of faceplate away from the phone. Follow snaps down, until faceplate is completely popped off. To remove the faceplate, pry the top of faceplate away from the phone. Follow snaps down, until faceplate is completely popped off.
  • To remove the faceplate, pry the top of faceplate away from the phone. Follow snaps down, until faceplate is completely popped off.
Aggiungi Commento
To remove battery push clip in; battery will pop out.
  • To remove battery push clip in; battery will pop out.
Aggiungi Commento
Using a Star 3.0 bit, remove 4 screws in battery compartment.
  • Using a Star 3.0 bit, remove 4 screws in battery compartment.
Aggiungi Commento
To separate front of phone from the back; start prying from bottom and work up the side. The phone should then pop apart. To separate front of phone from the back; start prying from bottom and work up the side. The phone should then pop apart.
  • To separate front of phone from the back; start prying from bottom and work up the side. The phone should then pop apart.
Aggiungi Commento
To remove keypad, turn front of phone over and let keypad fall out. All keys are connected by one rubber section.
  • To remove keypad, turn front of phone over and let keypad fall out. All keys are connected by one rubber section.
  • If a button had been ripped off your keypad, you can replace the entire rubber keypad at this step and reassemble phone.
Aggiungi Commento
To remove main-board from phone grab side of phone and pry upwards. Board should snap out. To remove main-board from phone grab side of phone and pry upwards. Board should snap out. To remove main-board from phone grab side of phone and pry upwards. Board should snap out.
  • To remove main-board from phone grab side of phone and pry upwards. Board should snap out.
Aggiungi Commento
To remove speaker cover, pull out silver plate.
  • To remove speaker cover, pull out silver plate.
Aggiungi Commento
After silver plate is removed, power button sits freely. Speaker can be removed by pulling up on it. If your speaker went out it can easily be replaced in this step with a new one, then reassemble phone after this step.
  • After silver plate is removed, power button sits freely. Speaker can be removed by pulling up on it.
  • If your speaker went out it can easily be replaced in this step with a new one, then reassemble phone after this step.
Aggiungi Commento
To remove keyboard circuit press on the middle and slide down. The board will pop up allowing for removal. To remove keyboard circuit press on the middle and slide down. The board will pop up allowing for removal.
  • To remove keyboard circuit press on the middle and slide down. The board will pop up allowing for removal.
Aggiungi Commento
To remove main-board from bracket, gently apply pressure to the four small clips. Board will pop out freely. To remove main-board from bracket, gently apply pressure to the four small clips. Board will pop out freely. To remove main-board from bracket, gently apply pressure to the four small clips. Board will pop out freely.
  • To remove main-board from bracket, gently apply pressure to the four small clips. Board will pop out freely.
Aggiungi Commento
To remove LCD screen pry back on highlighted clip and pull screen out. The screen will then pull up and out. If the LCD screen went out, or was cracked somehow, replace with a new LCD screen and then reassemble phone from this step.
  • To remove LCD screen pry back on highlighted clip and pull screen out. The screen will then pull up and out.
  • If the LCD screen went out, or was cracked somehow, replace with a new LCD screen and then reassemble phone from this step.
Aggiungi Commento
Andrew Foss
Membro da: 04/10/2011
10 Reputazione
1 Guida realizzata
UW Stout, Team 5-2, Zhou Fall 2011 Membro di UW Stout, Team 5-2, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G2
2 Membri
1 Guida realizzata
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 3,221
