Strumenti necessari in questo Smontaggio
Introduzione
I'm going to open my old Nokia phone to have a look.But I only have very limited English writing skills and I hope you'll understand what I'm talking about.
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Nokia 6108, usa il nostro manuale di assistenza.
Hello,I'm going to open my phone for some fun.
  • Hello,I'm going to open my phone for some fun.
    • Be careful not to drop any screws or parts when you're opening your phone.This may render your phone not usuable.Open your phone at your own risk.
Aggiungi Commento
Remove the following parts. Battery cover
  • Remove the following parts.
    • Battery cover
    • Battery
    • SIM card
  • Remove two trox screws marked in figure 2.
Aggiungi Commento
Remove the front panel by pulling it or using an I don't have a opening tool.So I used a flathead screw driver instead.
  • Remove the front panel by pulling it or using an
    • I don't have a opening tool.So I used a flathead screw driver instead.
  • Be careful not the damage the number pad connector(highlighted in red).If you break it.You'll have to replace the entre front panel.
Aggiungi Commento
Remove 5 trox screws that are holding the screen and the touch pad. Remove 5 trox screws that are holding the screen and the touch pad.
  • Remove 5 trox screws that are holding the screen and the touch pad.
Aggiungi Commento
After removing the touch pad and the screen.You can remove the logic board from the case. The board seem don't want to leave its cozy home.
  • After removing the touch pad and the screen.You can remove the logic board from the case.
  • The board seem don't want to leave its cozy home.
Aggiungi Commento
Let's start removing the parts under the logic board.
  • Let's start removing the parts under the logic board.
  • Parts need to be removed.
    • A motor
    • Charger connector
    • A speaker
Aggiungi Commento
Removing the EMI shield.Pry around the edge of the shield to remove it.
  • Removing the EMI shield.Pry around the edge of the shield to remove it.
Aggiungi Commento
Nothing under the EMI shield. I think we should stop here right now.There are pictures for all parts.
  • Nothing under the EMI shield.
  • I think we should stop here right now.There are pictures for all parts.
Aggiungi Commento
Honam1021
Membro da: 19/02/2011
322 Reputazione
1 Guida realizzata
i have same phone but it's keypad button's are not working.... can u help me that
Rohit Yadav - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 4,274
