Strumenti necessari in questo Smontaggio
Introduzione
Here is the disassembly for a Nikon Coolpix 3200 digital camera.
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Nikon Coolpix 3200, usa il nostro manuale di assistenza.
Use a small Philips screwdriver to remove the screws from the base of the camera.
  • Use a small Philips screwdriver to remove the screws from the base of the camera.
Aggiungi Commento
Use a small Philips screwdriver to remove the screws from the side of the camera where the computer lead is.
  • Use a small Philips screwdriver to remove the screws from the side of the camera where the computer lead is.
Aggiungi Commento
Use a small Philips screwdriver to remove the two screws from the side of the camera where the card reader is.
  • Use a small Philips screwdriver to remove the two screws from the side of the camera where the card reader is.
Aggiungi Commento
Pry apart the outer casing. A gray plastic threaded piece (used to attach camera to a tripod) will fall out.
  • Pry apart the outer casing. A gray plastic threaded piece (used to attach camera to a tripod) will fall out.
Aggiungi Commento
Use a Phillips screwdriver to remove the two silver screws that connect the circuit board to the outer front casing.
  • Use a Phillips screwdriver to remove the two silver screws that connect the circuit board to the outer front casing.
Aggiungi Commento
Pry apart the front outer casing from the circuit board. The camera will now be in three pieces.
  • Pry apart the front outer casing from the circuit board. The camera will now be in three pieces.
Aggiungi Commento
Pull the connecting strip on the circuit board which connects it to the back outer casing. Pull the connecting strip on the circuit board which connects it to the back outer casing.
  • Pull the connecting strip on the circuit board which connects it to the back outer casing.
Aggiungi Commento
Use a Philips screwdriver to remove the two screws next to the computer port and the brass screw on the circuit board. Use a Philips screwdriver to remove the two screws next to the computer port and the brass screw on the circuit board.
  • Use a Philips screwdriver to remove the two screws next to the computer port and the brass screw on the circuit board.
Aggiungi Commento
Use a Phillips screwdriver to unscrew the three screws that connect the outer lens rim to the front casing. Use a Phillips screwdriver to unscrew the three screws that connect the outer lens rim to the front casing.
  • Use a Phillips screwdriver to unscrew the three screws that connect the outer lens rim to the front casing.
Aggiungi Commento
Use a Philips screwdriver to remove the three screws that hold the flash cover to the outer front casing. Use a Philips screwdriver to remove the three screws that hold the flash cover to the outer front casing.
  • Use a Philips screwdriver to remove the three screws that hold the flash cover to the outer front casing.
Aggiungi Commento
Open the lid of the battery compartment and use a Philips screwdriver to remove the two screws at the bottom.
  • Open the lid of the battery compartment and use a Philips screwdriver to remove the two screws at the bottom.
Aggiungi Commento
Use a Phillips screwdriver to unscrew the two screws that connect the inside battery casing to the front of the outer casing.
  • Use a Phillips screwdriver to unscrew the two screws that connect the inside battery casing to the front of the outer casing.
Aggiungi Commento
Pull off the battery casing from the inside of the outer front casing. The circuit board, battery casing, and front outer casing will be attached by a connecting strip along with red and black wires.
  • Pull off the battery casing from the inside of the outer front casing. The circuit board, battery casing, and front outer casing will be attached by a connecting strip along with red and black wires.
Aggiungi Commento
Use scissors to cut the red and black wires away from the battery points of contact.
  • Use scissors to cut the red and black wires away from the battery points of contact.
Aggiungi Commento
Pull the connecting strip away from the circuit board to separate it from the front casing.
  • Pull the connecting strip away from the circuit board to separate it from the front casing.
Aggiungi Commento
Use a Philips screwdriver to unscrew the two screws that connect the photo button to the outer front casing.
  • Use a Philips screwdriver to unscrew the two screws that connect the photo button to the outer front casing.
Aggiungi Commento
Firmly press on the photo button and this component will pop out.
  • Firmly press on the photo button and this component will pop out.
Aggiungi Commento
Use a scalpel to pry apart the metal inner part of the button from the plastic outer piece. Use a scalpel to pry apart the metal inner part of the button from the plastic outer piece.
  • Use a scalpel to pry apart the metal inner part of the button from the plastic outer piece.
Aggiungi Commento
Use your fingernails to peel the outer rim from the front casing. Use your fingernails to peel the outer rim from the front casing.
  • Use your fingernails to peel the outer rim from the front casing.
Aggiungi Commento
  • Pull the connecting strip out of the circuit board to separate it from the LCD screen.
Aggiungi Commento
  • Use your fingernails to pry apart the back metal piece of the screen (covered by a black plastic film) from the front section of the screen.
Aggiungi Commento
Pry apart the back black piece and front white piece of the screen. Inside the screen there are four sheets of plastic: one opaque, two mirrored, and one thicker plastic sheet which has a foil piece attached to it.
  • Pry apart the back black piece and front white piece of the screen. Inside the screen there are four sheets of plastic: one opaque, two mirrored, and one thicker plastic sheet which has a foil piece attached to it.
Aggiungi Commento
  • Use a hammer and chisel to separate the lens piece of the camera from the circuit board.
Aggiungi Commento
  • Use your fingernails to pry off the motor, motor cover, and flash piece from the lens piece of the camera.
Aggiungi Commento
Milly Whitehead
Membro da: 09/03/2010
47 Reputazione
1 Guida realizzata
Oh, and then just do everything in reverse to put it back together again? That hammer and chisel bit bothers me a bit.
mrs_prolo - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 4,958
