Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo LG T310, usa il nostro manuale di assistenza.
  1. LG T310 Teardown, LG T310 Teardown: passo 1, immagine 1 di 1
    • Slide back cover down with hand in the direction of the arrow on the cover
    • Gently remove back cover
    • Remove the battery by inserting the plastic opening tool into the groove and gently prying it out
  2. LG T310 Teardown: passo 2, immagine 1 di 2 LG T310 Teardown: passo 2, immagine 2 di 2
    • Remove all of the screws on the back of the phone using a Phillips head screw driver
    • Slide out the SIM card from the phone
  3. LG T310 Teardown: passo 3, immagine 1 di 1
    • Using the plastic opening tool, pry off the shell of the phone, revealing the motherboard
  4. LG T310 Teardown: passo 4, immagine 1 di 2 LG T310 Teardown: passo 4, immagine 2 di 2
    • Using the plastic opening tool, gently pry the motherboard out (while doing this be sure not to pull on the mother board as it is attached to the touch screen)
    • Starting at the top left corner of the screen (with phone face down), insert your plastic opening tool and work down the left side.
    • The screen should be loose now making it possible to remove it from the case by hand (try not to touch the actual screen, only the side or back).
    • This completes the tear down of your LG-T310 Cookie
Andrew
Membro da: 11/07/13
116 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,389
