Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo LG G Watch R, usa il nostro manuale di assistenza.
  1. LG G Watch R Teardown, Front and Back: passo 1, immagine 1 di 2 LG G Watch R Teardown, Front and Back: passo 1, immagine 2 di 2
    • LG G Watch R assembly.
  2. LG G Watch R Teardown, Removing the back cover: passo 2, immagine 1 di 2 LG G Watch R Teardown, Removing the back cover: passo 2, immagine 2 di 2
    • First remove the watch band using a small flat screw driver to compress the spring loaded pin.
    • Remove the four T4 torx screws (Green).
    • Carefully pry the base off using a thin flat screw driver
  3. LG G Watch R Teardown, Removing the Board: passo 3, immagine 1 di 2 LG G Watch R Teardown, Removing the Board: passo 3, immagine 2 di 2
    • Disconnect the four electrical connectors from the board
    • Orange - Battery connector
    • Blue - button and charging connector
    • Green - Backlight
    • Purple - O-LED Controller + Mic
    • Remove the three phillips screws securing the board down. Then lift the board off the base
  4. LG G Watch R Teardown, The Battery: passo 4, immagine 1 di 2 LG G Watch R Teardown, The Battery: passo 4, immagine 2 di 2
    • The battery is below the board.
    • The battery can easily be pried out using a small flat head screwdriver.
  5. LG G Watch R Teardown, Battery housing: passo 5, immagine 1 di 1
    • Using a small pliers and a small flat screwdriver the battery housing comes out easily.
  6. LG G Watch R Teardown, P-OLED Panel: passo 6, immagine 1 di 3 LG G Watch R Teardown, P-OLED Panel: passo 6, immagine 2 di 3 LG G Watch R Teardown, P-OLED Panel: passo 6, immagine 3 di 3
    • Pictures of the front and back of the 1.3" P-OLED.
    • The screen is glued in.
8 Commenti
Is there a wifi antenna inside the LG G watch R?
Fernando Perez - Replica
Yes, there is a WiFi antenna inside the LG G Watch R, however WiFi functionality was only recently added to the G Watch R in a more recent update via Android Wear.
Mark Fortune -
Are there differences between the UK as US G Watch R?
James Kemble - Replica
Where could I find a battery for replacement?
Thanks in advance.
Fab - Replica
Any tips for what to check if the touchscreen turns on but is non-responsive ?
richard - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 20,259
