Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Impressa A9, usa il nostro manuale di assistenza.
  1. Jura Impressa A9 Teardown, Jura Impressa A9 Teardown: passo 1, immagine 1 di 2 Jura Impressa A9 Teardown, Jura Impressa A9 Teardown: passo 1, immagine 2 di 2
    • This machine cranks out caffeine at the touch of a button screen. Here are some of the highlights straight from Jura:
    • Touchscreen display
    • Twelve specialty coffees
    • High efficiency grinder
    • Height-adjustable dual spout with fine foam technology
  2. Jura Impressa A9 Teardown: passo 2, immagine 1 di 2 Jura Impressa A9 Teardown: passo 2, immagine 2 di 2
    • First things first—before we go for guts and glory we start with the basic, "user-replaceable" parts.
    • Removing the drip tray at the front and the water tank in the back is a cinch.
    • This can probably be performed half asleep, even before having your first cup in the morning.
  3. Jura Impressa A9 Teardown: passo 3, immagine 1 di 3 Jura Impressa A9 Teardown: passo 3, immagine 2 di 3 Jura Impressa A9 Teardown: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    Compra
    • Next up, we remove the Jura cover plate with a quick counterclockwise twist and find ourselves in an awkward situation...
    • This oval-headed screw isn't unique, but it's a rarity for sure. We had to dig through our 64 Bit and Macro Bit Kit before finding the right Oval bit in our Universal Bit Kit. If you just need the single Oval bit we have it here.
    • We were prepared for such an obstacle this time around, but finding security screws (when a simple Phillips could do the job) is always frustrating.
    • With the security screw defiantly removed, we slide up the side-panel locking latch and move right along.
  4. Jura Impressa A9 Teardown: passo 4, immagine 1 di 2 Jura Impressa A9 Teardown: passo 4, immagine 2 di 2
    Jimmy
    $7.95
    Compra
    • Even with the latch released, the side panels don't want to budge, so we turn our attention to the top of the case for more clues.
    • Our slim and sturdy Jimmy comes in handy to handle the mechanism on both sides beneath the cover plate.
  5. Jura Impressa A9 Teardown: passo 5, immagine 1 di 3 Jura Impressa A9 Teardown: passo 5, immagine 2 di 3 Jura Impressa A9 Teardown: passo 5, immagine 3 di 3
    • As a short intermezzo we take a look at the display which seems to have some kind of service port to gather information in case of a malfunction.
    • We flip it over, unscrew two small Phillips screws and discover the brains of this piece of modern coffee technology:
    • Renesas R5S72660W144FP 32-bit microcontroller
    • Macronix MX25L12835F 128Mb serial multi I/O NOR flash memory
    • Unisonic Technology MC34063A DC-DC converter
    • STMicroelectronics L7805CV 1.5 A voltage regulator
    • Oscillator
  6. Jura Impressa A9 Teardown: passo 6, immagine 1 di 3 Jura Impressa A9 Teardown: passo 6, immagine 2 di 3 Jura Impressa A9 Teardown: passo 6, immagine 3 di 3
    • Now all we have to do is simply grab a hold on the machine, poke the top latch, release the lower clasp, then slide the side panel out to the back. Right?
    • Despite all poking, prodding, doing the hokey pokey and turning ourselves around, the panel refuses to move.
    • Left with few options, we bring out the big guns to help negotiate our way inside.
    • With the right application of heat and strength, we finally manage to muscle the glass panel off the machine.
  7. Jura Impressa A9 Teardown: passo 7, immagine 1 di 3 Jura Impressa A9 Teardown: passo 7, immagine 2 di 3 Jura Impressa A9 Teardown: passo 7, immagine 3 di 3
    • Finally, with no glass panel to obfuscate its clip-in mechanism, we can see exactly where to focus our efforts.
    • The second time around our four-handed effort pays off and … et voilà, off comes the side panel.
    • No more heat gun drama on the other side—we can safely add this to the list of teardown skills we've mastered.
  8. Jura Impressa A9 Teardown: passo 8, immagine 1 di 3 Jura Impressa A9 Teardown: passo 8, immagine 2 di 3 Jura Impressa A9 Teardown: passo 8, immagine 3 di 3
    • After all this hustle we're relieved to find a handful of Torx screws securing the brewing unit on the machine's port side.
  9. Jura Impressa A9 Teardown: passo 9, immagine 1 di 3 Jura Impressa A9 Teardown: passo 9, immagine 2 di 3 Jura Impressa A9 Teardown: passo 9, immagine 3 di 3
    • Having found the brain behind the display, this would be the heart of the machine, providing power to every component.
    • Removing those colorful connectors and three Torx screws lets us get our hands on this junction.
    • Getting those back on in the right order will be a challenge, so we take a reference picture.
    • STMicroelectronics L7805CV 1.5 A / 5 V regulator
    • ON Semiconductor (formerly Fairchild Semiconductor) MOC3062M triac driver optocoupler
  10. Jura Impressa A9 Teardown: passo 10, immagine 1 di 3 Jura Impressa A9 Teardown: passo 10, immagine 2 di 3 Jura Impressa A9 Teardown: passo 10, immagine 3 di 3
    • Next we focus on the pump. After opening the metal clamp we unplug the hose running from the pump to the thermoblock.
    • The tube at the bottom can simply be pulled off by hand when taking out the unit.
  11. Jura Impressa A9 Teardown: passo 11, immagine 1 di 3 Jura Impressa A9 Teardown: passo 11, immagine 2 di 3 Jura Impressa A9 Teardown: passo 11, immagine 3 di 3
    • We follow the flow and remove the cover of the thermoblock which is secured by small plastic clips.
    • The thermoblock itself can be taken out by rotating it counterclockwise – no screws for this little nautilus.
  12. Jura Impressa A9 Teardown: passo 12, immagine 1 di 3 Jura Impressa A9 Teardown: passo 12, immagine 2 di 3 Jura Impressa A9 Teardown: passo 12, immagine 3 di 3
    • On our way to taking out the grinder we first have to take a look at the other side of the machine.
    • Here we will remove the powder chute for pre-ground coffee as well as the funnel and the guide tube for the powder chute.
  13. Jura Impressa A9 Teardown: passo 13, immagine 1 di 2 Jura Impressa A9 Teardown: passo 13, immagine 2 di 2
    • This reveals a small plastic frame which needs to be moved upwards to unlock the grinder.
  14. Jura Impressa A9 Teardown: passo 14, immagine 1 di 3 Jura Impressa A9 Teardown: passo 14, immagine 2 di 3 Jura Impressa A9 Teardown: passo 14, immagine 3 di 3
    • Back on the dark side of the moon the packed side of the machine we remove a small pin and three Torx screws to make the grinder pop out.
  15. Jura Impressa A9 Teardown: passo 15, immagine 1 di 2 Jura Impressa A9 Teardown: passo 15, immagine 2 di 2
    • The gear motor with its encoder attached is fixed with only two Torx screws.
  16. Jura Impressa A9 Teardown: passo 16, immagine 1 di 2 Jura Impressa A9 Teardown: passo 16, immagine 2 di 2
    • The connector of the drainage motor can easily be unplugged. Two more familiar Torx screws come loose and the motor is free.
  17. Jura Impressa A9 Teardown: passo 17, immagine 1 di 3 Jura Impressa A9 Teardown: passo 17, immagine 2 di 3 Jura Impressa A9 Teardown: passo 17, immagine 3 di 3
    • The ceramic valve is a little bit more tricky to get out. We need to remove some small tubes as well as two screws from the bottom where we also have to handle a pair of plastic notches to finally slide it out.
  18. Jura Impressa A9 Teardown: passo 18, immagine 1 di 2 Jura Impressa A9 Teardown: passo 18, immagine 2 di 2
    • With the bulk of the modules spread across our teardown table, the remaining guts are just a few hoses and pipes. We've earned a cup of coffee and the Impressa A9 has earned a repairability score of 7 out of 10 (10 is the easiest to repair):
    • The coffee maker is built with modular components that can be maintained separately. All screws inside are standard Torx.
    • There are no adhesives or one-way-clips used inside the machine. However the side panels with their glass front and tiny, invisible hooks are a major drag (even authorized technicians might struggle at this point).
    • The oval head screw behind the logo plate is one proprietary screw too many. The sole purpose of it is to keep you out.
    • There is no official documentation for repairs of internal components.
Tobias Isakeit
Membro da: 03/31/14
117.426 Reputazione
188 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.528 Guide realizzate
13 Commenti
I agree that its an oscillator / clock. The X1 screen printed on the PCB next to the item outlined in green, usually denotes X for Xtal (Crystal)
Geo - Replica
Thanks, we fixed it!
Jasper Fleischhauer -
Amazing work, but I have the Jura ena9 model. Is it a similar rigmarole?
Helen Price - Replica
Vielen Dank für die sehr schöne und detailierte Beschreibung. Sie hat mit heute sehr dabei geholfen, die Brüheinheit auszubauen und zu reinigen.Im Wesentlichen, ihr überhaupt durch die Seitenwände 'auf die Pelle zu rücken'. Hätte ich ohne die Anleitung wohl nicht geschafft bzw. gewagt!!!
Bernd Gröhbühl - Replica
Hallo Bernd,
freut uns zu hören, dass dir der Teardown helfen konnte.
Tobias Isakeit -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 12
Ultimi 7 Giorni: 83
Ultimi 30 Giorni: 413
Tutti i Tempi: 62,747
