Questo smontaggio non è una guida di riparazione. Per riparare il tuo Innovative Technology iPod Docking Station IT-5022WHT, usa il nostro manuale di assistenza.
Before Teardown Condition: Well used Noted issue: static sound when adjusting volume.
  • Before Teardown
  • Condition: Well used
  • Noted issue: static sound when adjusting volume.
Aggiungi Commento
Remove back battery panels. There are two: the main panel, and the smaller back up panel behind the main. Remove the 9 phillips screws. Remove the 9 phillips screws.
  • Remove back battery panels. There are two: the main panel, and the smaller back up panel behind the main.
  • Remove the 9 phillips screws.
Aggiungi Commento
Speakers Display & Logic Board Top panel buttons board
  • Speakers
  • Display & Logic Board
  • Top panel buttons board
  • Audio Jacks
  • DC Power Connector
  • Antenna
Aggiungi Commento
DC Power Board Audio Jacks board Remove the two screws
  • DC Power Board
  • Audio Jacks board
  • Remove the two screws
  • The boards are glued in, so carefully pry them out of the casing.
Aggiungi Commento
You can pull the antenna apart without opening the entire case. This is helpful if just part of the antenna is bent. For full removal, remove the screw on the bottom of the box labeled "antenna", and slide the antenna out the top. Coax cable connects the antenna to the tuning circuit on the upper PCB.
  • You can pull the antenna apart without opening the entire case. This is helpful if just part of the antenna is bent.
  • For full removal, remove the screw on the bottom of the box labeled "antenna", and slide the antenna out the top.
  • Coax cable connects the antenna to the tuning circuit on the upper PCB.
Aggiungi Commento
Remove three screws holding the three mounting brackets for each speaker. Use a blade to remove the glue holding the speaker wires in. Carefully pry the speakers off their mounting points because they are glued in.
  • Remove three screws holding the three mounting brackets for each speaker.
  • Use a blade to remove the glue holding the speaker wires in.
  • Carefully pry the speakers off their mounting points because they are glued in.
Aggiungi Commento
Removing the LCD Panel and motherboard. Removing the LCD Panel and motherboard. Removing the LCD Panel and motherboard.
  • Removing the LCD Panel and motherboard.
Aggiungi Commento
Remove 6 screws Pry out the panel by hand Careful of the volume and tuning nobs when pulling the board down
  • Remove 6 screws
  • Pry out the panel by hand
  • Careful of the volume and tuning nobs when pulling the board down
  • Check out that coil
Hi, Just wanna ask. I have this same unit but mine has a busted resistors: 1) R902 and 2) R908. Can you please help me identify the value of these 2 busted resistors? Thank you so much in advance. You can reply through my e-mail: july_477@yahoo.com
Leo - Replica
Hi leo. I don't have the product anymore, but resistors always have a color code on them. There are infographics available online that explain the color code. That's the best I can offer.
Dylan -
Overall this product was pretty easy to take apart.
  • Overall this product was pretty easy to take apart.
  • The internals were pretty easy to identify based on their location and appearance.
  • One drawback was that the speakers were glued in. The glue prevents rattling, but makes the speakers harder to get to. Some glue should be used when replacing the speakers.
  • 8/10 repairability
Aggiungi Commento
Dylan
Membro da: 24/11/2014
30 Reputazione
1 Guida realizzata
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 10
Tutti i Tempi: 698
