Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo HTC Evo 3D, usa il nostro manuale di assistenza.
  1. HTC Evo 3D Teardown, HTC Evo 3D Teardown: passo 1, immagine 1 di 1
    • First things first, Remove the back cover, battery and SD card.
  2. HTC Evo 3D Teardown: passo 2, immagine 1 di 1
    • Remove the four T5 Torx screws.
    • Then remove the two Phillips screws.
    • *Very sorry for dark image*
  3. HTC Evo 3D Teardown: passo 3, immagine 1 di 1
    • Once the screws are all out from the exterior back case, Begin separating the front housing from the back by using a spudger or any similar tool.
    • Begin from the bottom were the battery bay is, It is the easiest way.
    • Be careful of ribbons behind the plastic
  4. HTC Evo 3D Teardown: passo 4, immagine 1 di 3 HTC Evo 3D Teardown: passo 4, immagine 2 di 3 HTC Evo 3D Teardown: passo 4, immagine 3 di 3
    • Once separated begin to remove the LED board. Apply only light upward force and it will detach itself.
  5. HTC Evo 3D Teardown: passo 5, immagine 1 di 2 HTC Evo 3D Teardown: passo 5, immagine 2 di 2
    • Vibrator come's out easy, Just grab it by the wire and give it a little tug and it should come out.
    • Start unlocking the clips holding the ribbons. pull the white tab up to unlock.
    • Example: bottom left is unlocked, bottom right is locked. upper left has bin finished and removed.
    • Tuck the ribbons in without bending or making tears in them.
  6. HTC Evo 3D Teardown: passo 6, immagine 1 di 1
    • Behind the main board is two more ribbon's.
    • Flip both tab locks holding the ribbons and they will slide out vary easily, Don't force it.
    • Wifi/cellular antena port, Lift up cord head directly to remove and press straight down centered to put back on.
    • As a side note, the grey tape on the back side of the board was covering the clips so i cut a small section for this guide.
  7. HTC Evo 3D Teardown: passo 7, immagine 1 di 1
    • This concludes the (simple) teardown of the Evo 3D.
_Z_
Membro da: 03/18/12
9.668 Reputazione
2 Guide realizzate
Master Techs Membro di Master Techs
Community
321 Membri
1.468 Guide realizzate
Un commento
Thanks. This was very helpful.
dano706 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 31
Tutti i Tempi: 19,461
