Salta al contenuto principale
HP G62-453 Teardown
Cosa ti serve
  1. HP G62-453 Teardown, HP G62-453 Teardown: passo 1, immagine 1 di 2 HP G62-453 Teardown, HP G62-453 Teardown: passo 1, immagine 2 di 2
    • Remove the 2 panels and the battery at the bottom of the laptop.
    • After removing these panels, you'll see the RAM, HDD, and Wi-Fi module.
  2. HP G62-453 Teardown: passo 2, immagine 1 di 2 HP G62-453 Teardown: passo 2, immagine 2 di 2
    • Carefully remove the Wi-Fi antennas from the mini Pci-e adapter.
    • Note for reassembly: The black antenna attaches to 1 and the gray attaches to 2.
    • tip : Make a sketch of the laptop, where all the screws are, and how to put it back afterwards.
    • Remove the mini Pci-e Wi-Fi adapter by removing the small screw. Lift the screw side gently, then pull out.
  3. HP G62-453 Teardown: passo 3, immagine 1 di 2 HP G62-453 Teardown: passo 3, immagine 2 di 2
    • Now remove the HDD and the RAM
    • Remove the HDD by removing the three screws and pulling the Sata connector from the motherboard.
    • Remove the RAM by pulling apart the clips on either side of the top stick. The stick should pop up, then pull it out. Repeat for the bottom stick.
  4. HP G62-453 Teardown, Keyboard Screws: passo 4, immagine 1 di 2 HP G62-453 Teardown, Keyboard Screws: passo 4, immagine 2 di 2
    • Remove the 6 keyboard screws.
  5. HP G62-453 Teardown, DVD Drive Bay: passo 5, immagine 1 di 1
    • Remove the DVD drive bay by prying a little spudger between the case and the drive cover. Then gently pull it out.
    • The screws should already be removed from the removal of the panel.
  6. HP G62-453 Teardown, Case Screws Pt. 1: passo 6, immagine 1 di 2 HP G62-453 Teardown, Case Screws Pt. 1: passo 6, immagine 2 di 2
    • Next, we will remove the screws from the rest of the case.
    • Start by removing the screws hidden in the battery compartment (M2.5x3).
  7. HP G62-453 Teardown, Case Screws Pt. 2: passo 7, immagine 1 di 3 HP G62-453 Teardown, Case Screws Pt. 2: passo 7, immagine 2 di 3 HP G62-453 Teardown, Case Screws Pt. 2: passo 7, immagine 3 di 3
    • Now remove the 10 remaining case screws (M2.5x6.5).
    • There are 2 hidden screws in the HDD compartment (see last picture).
  8. HP G62-453 Teardown: passo 8, immagine 1 di 3 HP G62-453 Teardown: passo 8, immagine 2 di 3 HP G62-453 Teardown: passo 8, immagine 3 di 3
    • After removing all the screws, we can remove the keyboard.
    • Be careful because you can break keys or the entire keyboard.
    • Use a spudger to pry and search for the "locks"
    • use your hand to gently remove the keyboard. You will here clicks.
    • Be careful for the thin connector under the keyboard.
    • open the socket by clicking it up. pull the connector gently away from the socket.
  9. HP G62-453 Teardown: passo 9, immagine 1 di 2 HP G62-453 Teardown: passo 9, immagine 2 di 2
    • There are hidden screws under the keyboard. Remove them. (M2.5x6.5)
  10. HP G62-453 Teardown: passo 10, immagine 1 di 1
    • remove all the visible connectors.
    • the other connectors are from the power button and the mouse pad.
  11. HP G62-453 Teardown: passo 11, immagine 1 di 1
    • Now gently remove the case with a spudger and a isesamo opener.
    • Gently slide the spudger/opening tool to open the case.
    • You will hear clicks.
    • be careful for the connectors.
  12. HP G62-453 Teardown: passo 12, immagine 1 di 3 HP G62-453 Teardown: passo 12, immagine 2 di 3 HP G62-453 Teardown: passo 12, immagine 3 di 3
    • After you've removed the case you will see the motherboard.
    • Remove the screws from the motherboard.
  13. HP G62-453 Teardown: passo 13, immagine 1 di 2 HP G62-453 Teardown: passo 13, immagine 2 di 2
    • remove the connectors of the screen.
    • be careful with the connector (the bigger of the two.) (With the HP SPARE sticker)
    • Remove the sticker ( HP spare) And pull the connector out of the socket.
    • if you put back the screen and the connector afterwards , maybe you can tape the LCD cable to the motherboard with electrical tape. It will fit better then and you have less troubles with the screen.
  14. HP G62-453 Teardown: passo 14, immagine 1 di 2 HP G62-453 Teardown: passo 14, immagine 2 di 2
    • now we will remove the sata dock from the dvd player.
    • like the other connectors , just pull it out the socket. but be gentle.
  15. HP G62-453 Teardown: passo 15, immagine 1 di 2 HP G62-453 Teardown: passo 15, immagine 2 di 2
    • now remove the usb conncetor + the dc jack connector.
    • you can remove the dc jack (head) by pulling it out (sliding). if it's loose, then you can remove the connector from the motherboard.
    • if you remove the usb connector, be careful because the cable is taped to the case. pull gently
  16. HP G62-453 Teardown: passo 16, immagine 1 di 3 HP G62-453 Teardown: passo 16, immagine 2 di 3 HP G62-453 Teardown: passo 16, immagine 3 di 3
    • after removing all the cables/ wires and screws, we can remove the screws from the screen hinges.
    • after removing the screws from the hinges, put the entire screen apart.
    • we will remove the motherboard first. see picture 3. you can remove the motherboard by pulling it up and sliding it to the right.
  17. HP G62-453 Teardown: passo 17, immagine 1 di 3 HP G62-453 Teardown: passo 17, immagine 2 di 3 HP G62-453 Teardown: passo 17, immagine 3 di 3
    • if you have to remove the LCD screen connector you have to remove the case arround the screen. same thing if you have a broken screen..
    • be carefull if you remove the case around the screen. it's taped to the screen. i removed the case with an spudger. But first remove the 2 screws hidden under a black round sticker at the bottom of the screen, just above the grey hinges.
    • after removing the screws , slide the spudger arround the case, you will hear the clicks
  18. HP G62-453 Teardown: passo 18, immagine 1 di 2 HP G62-453 Teardown: passo 18, immagine 2 di 2
    • after removing the case. this is the screen internal.
    • above you will see the camera, the wifi antenna's . under you'll see the hinges and at the left the lcd connector.
    • you can remove the grey plastic caps by removing the screw(s), under the plastic cap you will find the cables running trough..
  19. HP G62-453 Teardown: passo 19, immagine 1 di 2 HP G62-453 Teardown: passo 19, immagine 2 di 2
    • you do the same thing at the other side.
    • if you remove, or going to remove the screen, be carefull with the cables, most of them are taped to the case or screen.
    • At the second picture you see the wires after removing the plastic grey cap. if you have problems with screen failure ( like a black screen or bad connection) its best to check this cable first before buying a new one. The wires are sliding to the cap and sometimes they get cut.
  20. HP G62-453 Teardown: passo 20, immagine 1 di 3 HP G62-453 Teardown: passo 20, immagine 2 di 3 HP G62-453 Teardown: passo 20, immagine 3 di 3
    • Now the last steps.. we will put some new coolpaste to the soldered CPU and GPU
    • first remove the 4 screws of the cooling socket.
    • remove the socket, be carefull for the little power socket attached at the motherboard, running to the cooling fan.
    • and than put some drop of cooling paste on the CPU/GPU
Conclusione
Altre 13 persone hanno completato questa guida.
Kevin D
Membro da: 05/02/14
7.276 Reputazione
21 Guide realizzate
16 Commenti
Would it be beneficial to remove old CPU and GPU thermal paste?
simmonsmarquis - Replica
If you are putting new paste to the cooler, Yes you have to remove the old thermal paste.
If you wonder only remove it because the laptop is heating up , i reccomand cleaning the whole laptop. Only the thermal paste will not be enough.
Kind regards,
Kevin
Kevin D - Replica
Show reverse for HP56 Cq notebook
Ray Walker - Replica
Please put together cq 56 notebookPc
Great instructions thank you!
I reassembled mine but now I cannot turn on the WiFi via the function button.
Everything else works.
I checked the two antenna cable are attached to the correct ones but still cannot turn on WiFi. Any suggestions appreciated
Robert Kehoe - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 26
Tutti i Tempi: 21,309
