Salta al contenuto principale
Dell Latitude 7420 Keyboard Replacement/Teardown
Cosa ti serve
  1. Dell Latitude 7420 Keyboard Replacement/Teardown, Remove backplate: passo 1, immagine 1 di 2 Dell Latitude 7420 Keyboard Replacement/Teardown, Remove backplate: passo 1, immagine 2 di 2
    • remove 8x screws with PH1 Screwdriver
    • Use finger nail or operning pick between backplate and frame at the top of the device
  2. Dell Latitude 7420 Keyboard Replacement/Teardown, Disconnect battery: passo 2, immagine 1 di 3 Dell Latitude 7420 Keyboard Replacement/Teardown, Disconnect battery: passo 2, immagine 2 di 3 Dell Latitude 7420 Keyboard Replacement/Teardown, Disconnect battery: passo 2, immagine 3 di 3
    • remove battery connector by pulling up. make sure the pulling strap is turned upwards
    • remove 5x screws with PH1
    • these are longer, do not mix them up!
  3. Dell Latitude 7420 Keyboard Replacement/Teardown, Disconnect speaker cable: passo 3, immagine 1 di 2 Dell Latitude 7420 Keyboard Replacement/Teardown, Disconnect speaker cable: passo 3, immagine 2 di 2
    • remove speaker cable by pulling towards yourself horizontally
    • lift out the battery vertically.
  4. Dell Latitude 7420 Keyboard Replacement/Teardown, disconnect ribbon cables: passo 4, immagine 1 di 3 Dell Latitude 7420 Keyboard Replacement/Teardown, disconnect ribbon cables: passo 4, immagine 2 di 3 Dell Latitude 7420 Keyboard Replacement/Teardown, disconnect ribbon cables: passo 4, immagine 3 di 3
    • open ribbon cable connectors by lifting up and away from you the black securing latch
    • carefully lift up ribbon cables and pull towards yourself
  5. Dell Latitude 7420 Keyboard Replacement/Teardown, disconnect headphone jack daughter board: passo 5, immagine 1 di 1
    • Insert wisdom here.
  6. Dell Latitude 7420 Keyboard Replacement/Teardown, disconnect fan: passo 6, immagine 1 di 1
    • pull horizontally to the rigt
  7. Dell Latitude 7420 Keyboard Replacement/Teardown, unscrew connector plates: passo 7, immagine 1 di 3 Dell Latitude 7420 Keyboard Replacement/Teardown, unscrew connector plates: passo 7, immagine 2 di 3 Dell Latitude 7420 Keyboard Replacement/Teardown, unscrew connector plates: passo 7, immagine 3 di 3
    • Use JIS00 or J00
    • display connector
    • wifi antenna connector
  8. Dell Latitude 7420 Keyboard Replacement/Teardown, unscrew connector plates: passo 8, immagine 1 di 2 Dell Latitude 7420 Keyboard Replacement/Teardown, unscrew connector plates: passo 8, immagine 2 di 2
    • use JIS00 or J00
    • unscrew connector plate
  9. Dell Latitude 7420 Keyboard Replacement/Teardown, disconnect cables: passo 9, immagine 1 di 3 Dell Latitude 7420 Keyboard Replacement/Teardown, disconnect cables: passo 9, immagine 2 di 3 Dell Latitude 7420 Keyboard Replacement/Teardown, disconnect cables: passo 9, immagine 3 di 3
    • lift upwards vertically
    • pull out horizontally away from you
  10. Dell Latitude 7420 Keyboard Replacement/Teardown, remove heat sink: passo 10, immagine 1 di 3 Dell Latitude 7420 Keyboard Replacement/Teardown, remove heat sink: passo 10, immagine 2 di 3 Dell Latitude 7420 Keyboard Replacement/Teardown, remove heat sink: passo 10, immagine 3 di 3
    • remove 6x screws using PH1
    • remove cable sticker from heat sink
    • if the thermal paste has dried out the heat sink can be stuck on. carefully wiggle it horizontally until you can lift it up vertically
  11. Dell Latitude 7420 Keyboard Replacement/Teardown, remove motherboard screws: passo 11, immagine 1 di 1
    • use PH1 for 2x mobo screws
  12. Dell Latitude 7420 Keyboard Replacement/Teardown, remove USB C screws: passo 12, immagine 1 di 3 Dell Latitude 7420 Keyboard Replacement/Teardown, remove USB C screws: passo 12, immagine 2 di 3 Dell Latitude 7420 Keyboard Replacement/Teardown, remove USB C screws: passo 12, immagine 3 di 3
    • remove 4x USB Screws with PH1
  13. Dell Latitude 7420 Keyboard Replacement/Teardown, USB C daughter board screws: passo 13, immagine 1 di 2 Dell Latitude 7420 Keyboard Replacement/Teardown, USB C daughter board screws: passo 13, immagine 2 di 2
    • remove 2x with PH1
  14. Dell Latitude 7420 Keyboard Replacement/Teardown, remove motherboard: passo 14, immagine 1 di 3 Dell Latitude 7420 Keyboard Replacement/Teardown, remove motherboard: passo 14, immagine 2 di 3 Dell Latitude 7420 Keyboard Replacement/Teardown, remove motherboard: passo 14, immagine 3 di 3
    • start on the right side at the USB C daughter board.
    • lift up the motherboard where the fan used to be
    • you should be able disconnect the daughterboard and mother board
    • the USB C port on the left might be tight. Use your fingers to slightly bend the laptop casing outward to the left above the usb c port
    • lift out the motherboard vertically
    • lift out USB C daughter board vertically. use the frame bending trick if necessary
  15. Dell Latitude 7420 Keyboard Replacement/Teardown, remove headphone jack daughter board: passo 15, immagine 1 di 1
    • remove 1x screw with PH1
    • lift out daughter board vertically
  16. Dell Latitude 7420 Keyboard Replacement/Teardown, unstick ribbon cables: passo 16, immagine 1 di 2 Dell Latitude 7420 Keyboard Replacement/Teardown, unstick ribbon cables: passo 16, immagine 2 di 2
    • carefully unstick glued on ribbon cables. use are card and pull up at 45° angle
    • no need to remove headphone jack cable
    • disconnect ribbon cable
    • be extremly careful not to pull at bends in the ribbon cables
  17. Dell Latitude 7420 Keyboard Replacement/Teardown, disconnect keyboard ribbon cables: passo 17, immagine 1 di 3 Dell Latitude 7420 Keyboard Replacement/Teardown, disconnect keyboard ribbon cables: passo 17, immagine 2 di 3 Dell Latitude 7420 Keyboard Replacement/Teardown, disconnect keyboard ribbon cables: passo 17, immagine 3 di 3
    • open connector as usual
    • the smaller ribbon cable has a different securing mechanism, look at the second image. it is opend from the other side
    • open connector from smaller ribbon cable at the white flap. NOT on top of the ribbon cable!
    • pull out ribbon cables
  18. Dell Latitude 7420 Keyboard Replacement/Teardown, remove keyboard backplate screws: passo 18, immagine 1 di 3 Dell Latitude 7420 Keyboard Replacement/Teardown, remove keyboard backplate screws: passo 18, immagine 2 di 3 Dell Latitude 7420 Keyboard Replacement/Teardown, remove keyboard backplate screws: passo 18, immagine 3 di 3
    • use JIS00 or J00 to remove 19x screws
    • go around perimeter of the backplate in a orderly fashion when removing the screws to not miss any
  19. Dell Latitude 7420 Keyboard Replacement/Teardown, remove keyboard with backplate: passo 19, immagine 1 di 2 Dell Latitude 7420 Keyboard Replacement/Teardown, remove keyboard with backplate: passo 19, immagine 2 di 2
    • lift up keyboard vertically
    • be careful: ribbon cables might be sticky
  20. Dell Latitude 7420 Keyboard Replacement/Teardown, removing keyboard from backplate: passo 20, immagine 1 di 3 Dell Latitude 7420 Keyboard Replacement/Teardown, removing keyboard from backplate: passo 20, immagine 2 di 3 Dell Latitude 7420 Keyboard Replacement/Teardown, removing keyboard from backplate: passo 20, immagine 3 di 3
    • use PH1 to unscrew backplate from front of keyboard
  21. Dell Latitude 7420 Keyboard Replacement/Teardown, clean CPU and Heat Sink: passo 21, immagine 1 di 2 Dell Latitude 7420 Keyboard Replacement/Teardown, clean CPU and Heat Sink: passo 21, immagine 2 di 2
    • remove old thermal paste using isopropyl alcohol and a cloth
    • apply new thermal paste
  22. Dell Latitude 7420 Keyboard Replacement/Teardown, backplate: passo 22, immagine 1 di 1
    • keyboard backplate
    • when you are done with reassembly do not panic, the first boot takes a little longer after disconnecting the battery
    • after reassembly press inbetween keyboard keys to klick together backplate and notebook frame
Conclusione
Altre 3 persone hanno completato questa guida.
fixer
Membro da: 07/05/16
862 Reputazione
3 Guide realizzate
2 Commenti
Steps 10 and 13 are not necessary (motherboard could be removed together with a head sink)
Alex - Replica
After following this very useful guide my new keyboard was not working, when you reconnect all the ribbon cable take some time to reconnect them better then I have done :-D
If something is not working double check the ribbon cables connection before doing anything else.
daniele - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 46
Ultimi 30 Giorni: 215
Tutti i Tempi: 3,604
