Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Caterpillar B15, usa il nostro manuale di assistenza.
  1. Caterpillar B15 Teardown, Caterpillar B15 Teardown: passo 1, immagine 1 di 1
    • Place the phone screen-side down and place thumb on the yellow and black switch. Slide the switch to the right to unlock the back covering for removal.
  2. Caterpillar B15 Teardown: passo 2, immagine 1 di 2 Caterpillar B15 Teardown: passo 2, immagine 2 di 2
    • Remove the back covering by gently lifting upwards from the bottom of the back covering. The back will snap off and the battery is exposed.
  3. Caterpillar B15 Teardown: passo 3, immagine 1 di 2 Caterpillar B15 Teardown: passo 3, immagine 2 di 2
    • Place index finger at the top edge of the battery and gently lift upwards. The battery will slide cleanly out of the phone.
  4. Caterpillar B15 Teardown: passo 4, immagine 1 di 2 Caterpillar B15 Teardown: passo 4, immagine 2 di 2
    • With the back cover removed, locate and remove the Phillips screw pictured top-center, and the two torx screws above and to either side of the Phillips screw. A T-5 bit is required for removal of the torx screws.
    • WARNING: Proceeding beyond this point will void the warranty for this device.
  5. Caterpillar B15 Teardown: passo 5, immagine 1 di 1
    • Next, remove the two torx (star-shaped) screws below the battery. These screws help to secure the outer shell of the phone around the motherboard. A T-5 bit is required for removal.
  6. Caterpillar B15 Teardown: passo 6, immagine 1 di 1
    • There are three remaining screws on each long side of the phone. A small hex bit is required for removal.
  7. Caterpillar B15 Teardown: passo 7, immagine 1 di 1
    • There is one more Phillips screw remaining. It is located beneath the headphone cover.
  8. Caterpillar B15 Teardown: passo 8, immagine 1 di 1
    • With all screws removed, the back and side pieces should come off the front of the phone, exposing the motherboard and various components as shown.
  9. Caterpillar B15 Teardown: passo 9, immagine 1 di 1
    • With all screws removed, move around the motherboard, carefully prying it from the remaining shell.
  10. Caterpillar B15 Teardown: passo 10, immagine 1 di 1
    • Finally, disconnect the chip seen in the upper right, and the board should pull away from the rest of the phone.
  11. Caterpillar B15 Teardown: passo 11, immagine 1 di 1
    • Congratulations. You have successfully disassembled the Caterpillar B15.
USF Tampa, Team 4-7, Brown Fall 2014 Membro di USF Tampa, Team 4-7, Brown Fall 2014
USFT-BROWN-F14S4G7
4 Membri
10 Guide realizzate
2 Commenti
Hi,
where can i buy T5 Torx screws for CAT B15 ?
Regards,
Laurent NOEL
Laurent NOEL - Replica
Any idea where I can get the rubber piece that covers the USB port? The one repair shop in the US wants about $200 for that repair.
John Nagle - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 18
Tutti i Tempi: 11,417
