Introduzione
This teardown is a working Actiontec Q1000 Modem, sold by Qwest as a Qwest Q1000.
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Actiontec Q1000 DSL Modem, usa il nostro manuale di assistenza.
The Qwest Q1000 modem, made by Actiontec. Port side with antennas detached. DSL and Phone in ports
  • The Qwest Q1000 modem, made by Actiontec.
  • Port side with antennas detached.
    • DSL and Phone in ports
    • 4 Ethernet ports
    • USB port, reset button, and power jack
  • Not a screw in sight.
Aggiungi Commento
As usual, the rubber feet are hiding screws! As usual, the rubber feet are hiding screws! As usual, the rubber feet are hiding screws!
  • As usual, the rubber feet are hiding screws!
Aggiungi Commento
Nothing really to see here... Remove the 2 antenna wires from the wifi card. One is also taped to the back of the board. The circuit board is finally free!
  • Nothing really to see here...
  • Remove the 2 antenna wires from the wifi card. One is also taped to the back of the board.
  • The circuit board is finally free!
Aggiungi Commento
Looks like someone was generous with the thermal paste. Underneath the cover:
  • Looks like someone was generous with the thermal paste.
  • Underneath the cover:
    • Broadcom BCM6366
    • Broadcom BCM53115
Aggiungi Commento
The Wi-Fi card lets down its shield... The chip is a BCM4322.
  • The Wi-Fi card lets down its shield...
  • The chip is a BCM4322.
Aggiungi Commento
The inside of the top case. The antenna connectors are screwed onto the case.
  • The inside of the top case.
  • The antenna connectors are screwed onto the case.
Aggiungi Commento
The antenna connectors have gold-plated coax connectors and standard Wi-Fi antenna connectors. What's underneath the heat-shrink? A ferrite bead to minimize interference.
  • The antenna connectors have gold-plated coax connectors and standard Wi-Fi antenna connectors.
  • What's underneath the heat-shrink? A ferrite bead to minimize interference.
Aggiungi Commento
Testing out the light pipe with an LED throwie... The light pipe takes light from tiny surface-mount LEDS on the motherboard and refracts it to the panel. Here are all the LEDS:
  • Testing out the light pipe with an LED throwie...
  • The light pipe takes light from tiny surface-mount LEDS on the motherboard and refracts it to the panel.
  • Here are all the LEDS:
    • 8 of the LEDS that work with the light pipe
    • One more surface mount LED
    • A white LED for illuminating the Qwest logo
    • A dual-color (red/green) LED for the WPS status indicator.
Aggiungi Commento
The empty shell that once held a DSL modem. The 2 detachable Wi-Fi antennas. Nothing to tear down here! The 2 detachable Wi-Fi antennas. Nothing to tear down here!
  • The empty shell that once held a DSL modem.
  • The 2 detachable Wi-Fi antennas. Nothing to tear down here!
Aggiungi Commento
Repairability score: 8/10
  • Repairability score: 8/10
  • The entire device is held together with only 4 screws.
  • The Wi-Fi antenna connectors are screwed in and the cables are not soldered to the board.
  • The antennas are replaceable as well.
  • The heat sink is soldered in place, making removal difficult.
  • The Wi-Fi card is soldered in and held in place with silicon adhesive, making it impossible to remove without damaging the card or the device.
Aggiungi Commento
Documenti Allegati
jrw01
Membro da: 22/08/2013
1.105 Reputazione
23 Guide realizzate
Awesome teardown! These things have gotten so simple. Those antennas would be pretty easy to repurpose for something else.
Kyle Wiens - Replica
What are the part number, volts, and amps of the power supply?
PDXTek - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 40
Tutti i Tempi: 5,345
