Salta al contenuto principale
« Torna a Tutte le Storie
iMac HDD Replacement
Joseph Abraham -
iMac Intel 20" EMC 2133 and 2210
Immagine Storia
iMac Intel 20" EMC 2133 and 2210 Hard Drive Replacement
1 ora
Moderate
Il Mio Problema
Original hard drive went bad, had to replace it.
La Mia Riparazione
Repair went smooth. However, I did forget to attach one cable prior to reassembly. I had to open the unit back up and reattach the video cable. I ended up actually shocking myself because when I reopened the computer, I forgot to unplug the computer.
Also, wasn't able to install the operating system from the DVD drive for some reason. I ended up cloning a drive that was plugged in via USB; I used disk utility.
Il Mio Consiglio
First, never work on an iMac when it is plugged in. There is a possibility of lethal electric shock. Second, in many instances, cloning drives with disk utility is more time effective than reinstalling from recovery disk.
Immagine 4 TB 3.5" Hard Drive
$172.99
0 Commenti
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 6
Tutti i Tempi: 229
