Broken pwr button - rplcd pwr button, volume buttons, mute switch, hdphone jack
mmbt -
Difficult
Il Mio Problema
Would not power on or off using power button
La Mia Riparazione
Following directions, repair went great. Be prepared for it to take at least two hours, have a good lighting source and a safe place to store very small screws. Cable itself is somewhat difficult to work with.
Il Mio Consiglio
The hardest part is the mute switch. There is a small pad that needs to be positioned correctly on the external plastic switch body and the mute switch needs to fit into a small opening in the external plastic switch body. I could never get it right until I used a tiny bit of glue from the battery to hold the pad in place and to hold the switch in the correctly aligned position. After that, no problem.
0 Commenti
