Salta al contenuto principale
« Torna a Tutte le Storie
Front Load Washing Machine Spinner Repair – Smooth Spin Restored!
Appliance Care India -
Immagine Storia
  • Immagine n.1
  • Immagine n.2
  • Immagine n.3
Il Mio Problema
The washing machine’s spinner had completely stopped working, leaving clothes soaking wet after every wash cycle. The client needed a quick and effective solution because laundry was piling up, and the machine is used daily in their household.
La Mia Riparazione
The repair involved carefully dismantling the front panel, inspecting the motor, and checking for drum obstruction. The issue was traced to a worn-out drive belt and minor motor alignment problem. We replaced the belt, adjusted the motor, and performed a test cycle. The spinner worked flawlessly, leaving the client extremely satisfied.
Il Mio Consiglio
Regular maintenance is key! Clean the filter monthly, avoid overloading the machine, and call a technician at the first sign of strange noises or failed spins. Early washing machine repair can prevent major damage and save money.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 413
