Salta al contenuto principale
« Torna a Tutte le Storie
Quickly repair cracks in laptop shells - a low-cost solution to save money
CC wang -
Immagine Storia
Il Mio Problema
1. Cost issue: It is too expensive to replace the entire bottom shell of a branded machine, and the actual damage is only a local area near the hinge.
2. Environmental considerations: 30% of electronic waste comes from "structural damage" that can be repaired.
La Mia Riparazione
I referred to the "Notebook shell structural repair" guide on the Tengzhong (https://tengzhongtec.com/) website, and the blog on the website also has detailed solutions.
1. Test model: HP EliteBook 840
2. Time: 15 minutes/unit
3. Durability test: Pass 5,000 opening and closing cycles
Il Mio Consiglio
Make protective preparations in advance, such as sticking aramid fiber tape on the hinge position, which can prevent 80% of breaks.
If you need to do high-volume repairs, look for a supplier that uses UV-cured epoxy, which can be 300% more efficient.
Immagine Moray Driver Kit
Moray Driver Kit
$19.95
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 61
Tutti i Tempi: 61
