Salta al contenuto principale
« Torna a Tutte le Storie
Killing the Noise
Zaair Vasquez -
Immagine Storia
Il Mio Problema
My PS4 Pro sounded like a jet engine and for prolonged periods of play time it would shut down because of the heat
La Mia Riparazione
It was smooth and easy with IFixit's Mako Driver Kit. The Artic Silver 5 Thermal Paste they have in stock is wonderful, now my Pro runs quietly and heat transfers more efficiently. It doesn't make the system cooler, but it transfers the heat from the chip faster and more effectively.
Il Mio Consiglio
Take your time, don't rush. I suggest to take pictures before every section you disassemble so you can see where each screw, wire and connection was before you take it apart. Although, I did not use a guide, I suggest you watch a video, do some research or go through a guide before attempting to disassemble anything.
Immagine Mako Driver Kit - 64 Precision Bits
$39.95
0 Commenti
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 17
Tutti i Tempi: 221
