Il Mio Problema
The color scheme on my old screen started disinigrating and needed to be replaced.
La Mia Riparazione
The repair went okay. It took a bit longer than anticipated because I couldn't get the ribbon cable in the hinge properly. That took me about an hour alone. I also swapped 2 screws, oops. No big deal though as they were about the same size and worked in the holes I put them in.
Il Mio Consiglio
Double check that you have the screen faceplate on the correct way before trying to close it all up. It may cause frustration if you don't.
0 Commenti
