Salta al contenuto principale
« Torna a Tutte le Storie
Love the kits and guides!!
imthetyke -
iPhone 4
iPhone 4 Pentalobe Screws Replacement
1 minuto
Easy
Il Mio Problema
2 shattered screens and 2 underperforming batteries..
La Mia Riparazione
The first screen took a LONG time.. Mostly because it was my first time in the guts of the iPhone..
Second time went much quicker, and easier..
Il Mio Consiglio
When you are at the step removing screws from the corners of the frame of the iPhone - just before you remove the display, go ahead and remove the headphone jack. Removing the jack makes replacing the corner screw next to it ever so much easier..
I also followed another users advice and used a separate small plastic container for each step of the process where something was removed, I then labelled the container so it was easy to go in reverse order to put back together.. The second screen, I already had labelled containers.
Lastly, get a good magnifying device , preferably mounted on arms,so you can more easily see all the tiny components you are dealing with.
Immagine iPhone 4S Screen
iPhone 4S Screen
$39.99
Immagine iPhone 4S Screw Set
iPhone 4S Screw Set
$9.99
Immagine Tweezers
Immagine iPhone 4/4S Liberation Kit
$9.99
Aggiungi Commento
