SuperDrive Replacement on MacBook Pro Model A1260
edmunds -
Il Mio Problema
The SuperDrive would not accept a disk.
La Mia Riparazione
The repair went very smoothly.
Il Mio Consiglio
Step 10 of the repair guide suggests you remove the ribbon cable attaching the SuperDrive connector to the logic board. I found this to be unnecessary. After removing the three screws holding the drive in place, I was able to lift the drive gently and slide it off the connector. Slipping the new one on the connector was just as easy. I try to avoid separating ribbon cables if I can avoid it.
0 Commenti
