iSesamo Opening Tool
  • iSesamo Opening Tool
  • 360°
360
9,99 US$
9,99 US$
Ti invieremo un messaggio quando il prodotto sarà nuovamente disponibile.
Dettagli Prodotto
Descrizione
Descrizione
Crafted for one purpose
A thin sheet of springy steel, designed to slide easily between panels and into microscopic cracks. An expertly curved tip, perfected to get the right angle on electronic casing clips. And with a no-slip grip, this tool is much more effective and reliable than other case opening methods.
  • This tough tool nimbly pops open modern small electronics casings.
  • Springy steel blade features a smart tip design and a handle with a great no-slip grip.
Be sure to exercise caution when using this tool. With its great strength comes the potential to scratch or otherwise damage components that might be better served with plastic tools such as a spudger or plastic opening tool.
Video del Prodotto
Storie di Riparazione
tomm's Story Photo #1334078
Il Mio Problema
iPod Photo purchased when first released. Replaced battery using iFixit parts, tools, and guide six or seven years ago. That battery started quitting when indicating about 1/2 charged. Decided time to fix it again.
La Mia Riparazione
I couldn't get the case open. Trying from the right side as indicated in the guide . . .
Il Mio Problema
Yes I’m learning how to repair iPhones with these tools. Thank you!
La Mia Riparazione
It went good
Il Mio Consiglio
I fixed an iPhone 5s
Il Mio Problema
My phone got dropped at the airport and cracked the upper left corner of just the glass, still worked fine, but I researched changing the glass only and most of the feedback indicated that you'd damage the digitizer in the process so I opted to order the screen and digitizer assembly. My wife had d . . .
Il Mio Problema
Reemplace el conector de carga, la guía me sirvió mucho :)
La Mia Riparazione
Fue un poco complicada pero al fin y al cabo logré la reparación
Il Mio Consiglio
Usen una luz blanca para prestar atención al lcd, este se podría quemar por el calor
Il Mio Problema
An older iPhone 4 with a cracked screen was going to waist in my dresser. I found myself reading for it when my new fone was on the charger but e screen was a mess.
La Mia Riparazione
The repair wint great. No issues not if is a pleasure to use for late nite browsing and email. I forgot hi good the smal screen actu . . .
Il Mio Problema
My iphone 6 screen was broken and i bought from another seller and it appeared to be of poor quality so i decided to buy from ifixit and it went all well
La Mia Riparazione
Smooth. I had the islack which works like a charm. Easy to open the iphone
Il Mio Consiglio
Buy from reliable sources like ifixit
Il Mio Problema
My daughter cracked her iPhone 5S screen while at college after only having the phone for about 5 months. I decided I would fix it myself while she was home for Christmas break. I also decided that while I was at it, I would fix her older iPhone 4S cracked screen and sell that phone to help pay fo . . .
Il Mio Problema
I was tasked with replacing the battery in 14 Ipad Gen 1's - That seemed easy enough, since I'd been repairing PC for Years.
La Mia Riparazione
The Repair started out ok I received my tools, and went right to work, using the iSesamo Tool I opened the first ipad pretty easy, The only issue I have with the iSesamo Tool i . . .
Il Mio Problema
The charging port on my iPhone 5 was shorted.
La Mia Riparazione
After looking at the repair guide for a while, I managed to open and fix the iPone for the first time in about an hour.
Il Mio Consiglio
Pay attention to how you remove the loudspeaker. That almost tripped me up while reinstalling.
Il Mio Problema
Wacko iPad decided to fly out of my hand. All went well for about 2 seconds, then it fell down a flight of concrete and steel stairs.
La Mia Riparazione
All went as described. My only problem was the chassis was somewhat deformed at the corners, causing some difficulty fitting the bezel. Turned out okay though.
Il Mio Consiglio
Dry fit . . .
Mostra di più
