Dettagli Prodotto
Descrizione
- Don't let blown capacitors or fried transistors stop your electronics! With this soldering station, you'll have everything you need to be the ultimate solder soldier.
- Build your own speaker cables for that extra audiophilliac edge, or get hacking on a brand new robotics project. The possibilities are endless.
Contenuto del kit
- Soldering Iron - the necessary tool for putting heat where you want it
- Lead-Free Solder - holds electrically conductive components together
- Solder Wick Braid - removes old solder from PCBs and wires
- Tip Cleaner Ball - clean excess solder and oxidation off your soldering iron tip
- Heat Shrink Tubing Assortment - insulate soldered wire connections
- Spudger - great for holding components and routing wires
- Flush Cutter - trim wires down to the right length
- Helping Hands - extra set of hands for holding things in place
- Hemostat - makes a great heat sink to protect components
- Safety Glasses - always a good idea!
Recensioni dei clienti
