Phillips #2 Screwdriver
  • Phillips #2 Screwdriver
2,99 US$
2,99 US$
Ti invieremo un messaggio quando il prodotto sarà nuovamente disponibile.
Spedizione gratuita per tutti gli ordini superiori a 100,00 US$ o contenenti un Kit Attrezzi Pro Tech!
Sfoglia il Nostro Negozio
Dettagli Prodotto
Descrizione
Descrizione
Unless you require a #2 Phillips driver for a deeply recessed screw, we recommend purchasing our 6-in-1-Screwdriver, which includes a Phillips #2 driver.
Storie di Riparazione
Avatar utente
Il Mio Problema
Computer was constantly running fans with little to no actual load. Upon closer investigation the computer was getting as high as 90 degrees Celsius when doing moderately demanding tasks.
La Mia Riparazione
Opened the case and saw a bunch of dust everywhere. After the dust was removed the real problem revealed itself. . . .
Avatar utente
Il Mio Problema
Replaced built in optical drive with 250GB SSD drive. System was running really slow.
La Mia Riparazione
It went well. Followed instructions and was pretty straight forward. Ran into a few hurdles....The screws can easily fall down into the case, which was very annoying. There is also a cable that has a very sensitive . . .
Avatar utente
Il Mio Problema
No facilities available in Australia, apparently.
La Mia Riparazione
Quite ok. Thanx for online instructions.
Il Mio Consiglio
Spludger
invaluable.l
Avatar utente
Il Mio Problema
My iMac 27 Inch i5 always frozen...
La Mia Riparazione
Very well, I managed to happily. It 'just install "Fan control" fan set at maximum speed and the problem is solved!. For an excess of zeal, oh then apart my iMac 27 to carry out additional cleaning.
Il Mio Consiglio
No, nothing special
Avatar utente
Il Mio Problema
The power supply of my Imac was broken
La Mia Riparazione
My iMac is a 24" aluminum one, unfortunately there was no official guide on the website. However, there was a guide for changing the power supply in a 20" iMac, so I used that. There was also a video of the friendly lady, who made the repair look very easy. I al . . .
Mostra di più
