Essential Electronics Toolkit
  • Essential Electronics Toolkit / New
  • 360°
360
Limit 5 per customer.
$19.99
$19.99
Ti invieremo un messaggio quando il prodotto sarà nuovamente disponibile.
Dettagli Prodotto
Descrizione
Descrizione
Our most economical do-everything toolkit. The Essential Electronics Toolkit is what you need for the most essential electronics repairs—like screen and battery swaps—and everything you need for most household DIY fixes.
Get started in electronics repair with all the bits and precision tools to handle your most urgent screen breaks and battery swaps. Or simply upgrade your home DIY toolkit with what you need to service door knobs, home appliances, eyeglasses, and more.
Toolkit Includes
Storie di Riparazione
Avatar utente
Sean Lichtenstein's Story Photo #1330869
Il Mio Problema
Cracked/Smashed IPhone 6S screen
La Mia Riparazione
It went well! A little more difficult than I expeted but the guides were a fundamental help with this repair- I would not have been able to complete it without them!
It was a bit tricky getting the Home button in place as well as the earpiece speaker and camera- but . . .
Avatar utente
Il Mio Problema
power brick went out in the XBox
La Mia Riparazione
The repair was fairly easy. Although the only issues i had was not putting bottom metal cover on before i closed it up. So had to take apart. Then put back together. Then realized i let a few screws out. haha so took apart again installed screws and put back together, . . .
Avatar utente
Il Mio Problema
OEM battery was no longer holding charge
La Mia Riparazione
Awesome! ifixit tool kit was a huge help
Il Mio Consiglio
Don’t attempt this without a iPod opening tool.
Avatar utente
Il Mio Problema
Battery was old and drained quickly.
La Mia Riparazione
It didn’t take 45 min. 25 is more accurate.
Il Mio Consiglio
Instead of trying to pull the glue, heat it up for a minute and the battery comes right off.
Avatar utente
Il Mio Problema
I had a guy from Facebook come and ask me to repair his iPhone 6 Plus screen because he saw a recent post that showed I can do that
La Mia Riparazione
It went flawlessly
Il Mio Consiglio
I know by heart the way around an iPhone but if you don’t, and not many people do, I suggest to use their instructional videos
Avatar utente
Il Mio Problema
It had the 3 beep of death. I purchased 2, 8s of ram for a total of 16, however. It would not allow this. So ended up with 10gb. Initially I thought I had a bad top ram slot. But the 2gb took. But had to put them in one at a time to test them. I truly would not wanted to replace the logic board. S . . .
Avatar utente
Il Mio Problema
I replaced the battery, fan, and right speaker/subwoofer
La Mia Riparazione
Took my time and reviewed videos over and over. Everything went smoothly.
Il Mio Consiglio
for images, I would show the before and after shot of how to remove certain connections. I didn't know how to remove a certain piece from your website, but found out fro . . .
Avatar utente
Il Mio Problema
My MacBook Pro Early Rubber Feet has left and I was replace it with MBP Rubber Feet that i was buy on iFixit Store. I buy Essential Electronics Toolkits to do this.
La Mia Riparazione
First, i replace botoom case my MacBook Pro and then replace 4 rubber feet.
Just do it.
Il Mio Consiglio
You don't need adhesive 'cause iFixit MBP Rubber . . .
Avatar utente
Il Mio Problema
Still using the original battery in 2018 so decided it was time.
La Mia Riparazione
Replacement went smoothly -- except for the enclosed tools. I recommend purchasing the toolkit to avoid stripping the screws.
Il Mio Consiglio
The four screwdrivers are really just toys; please either spring for a better set of just do away with them.
Avatar utente
Il Mio Problema
Hard drive died. My first delve into computer guts. Drive seemed fine, head not stuck, but made clicking noise. Decided I wouldn't be able to recover. Maybe circuit board... Bought Evo 256Gig SSD and while looking around the delightful ifixit site, discovered the discussions about upgrading the . . .
Mostra di più
