Detailing Brush
  • Detailing Brush / Nylon
  • Detailing Brush / Brass
Detailing Brush
Like a toothbrush on steroids, this double ended brush will fit in tight spaces and quickly cleans up battery acid damage, residue from spills, corrosion from water damage, dust, and thermal paste residue.
Please Note - This brush is safe for most applications, but is not an official "ESD safe" tool.
2,99 US$
2,99 US$
Ti invieremo un messaggio quando il prodotto sarà nuovamente disponibile.
Dettagli Prodotto
Descrizione
Descrizione
No more worn out toothbrushes with bent bristles, these economic professional tools will do the job faster and better, fitting into more places, and don't require handle bending pressure to do a good job. These bristles are ready to scrub and clean with minimal effort.
Storie di Riparazione
Il Mio Problema
Water damage on a macbook pro.
There was a dime sized bit of corrosion on the logic board and it would not turn on.
La Mia Riparazione
Pulled the back off, unhooked the battery, stogged the corroded bits with a really soft brush and alcohol. Let it dry, put it back together and it turned back on.
Il Mio Consiglio
Be brave...
Il Mio Problema
I am just starting out in the repair business, I repair all sorts of electronics, mainly the repairs are either Mobile Devices, Laptops, Computers. IFIXIT.com has a lot of the tools that are required for repairing these devices.
La Mia Riparazione
Repairs go a lot quicker with the right tools.
Il Mio Consiglio
Make sure you have the ri . . .
Il Mio Problema
Bass from speakers just come out as muddled.
La Mia Riparazione
Removed without much trouble.
Il Mio Consiglio
The original screws securing the sub-woofer strips quit easily. Pay attention when removing them. I had to discard one screw I stripped. Luckily I could remove them by forcing the screwdriver into the screw to create new indent . . .
Il Mio Problema
Silly Tri-Tip screwdrivers, lucky ifixit came to the rescue!
La Mia Riparazione
Excellently
Il Mio Consiglio
Make sure you order the right battery from Amazon, it's too bad that ifixit doesn't stock batteries for newer Macbook Pro's
Il Mio Problema
Just needed some more tools for opening Apple Mac's, Getting out laptop screws that have had there heads destroyed and the magnetic project mat for the laptop screws.
La Mia Riparazione
Always good
Il Mio Consiglio
By the right tools for the right job and it always easier.
Mostra di più
