Unibody 8x SATA SuperDrive (Pre-Mid 2009)
  • Unibody 8x SATA SuperDrive (Pre-Mid 2009) / Used
Condizione: Usato
49,99 US$
49,99 US$
Ti invieremo un messaggio quando il prodotto sarà nuovamente disponibile.
Spedizione gratuita per tutti gli ordini superiori a 100,00 US$ o contenenti un Kit Attrezzi Pro Tech!
Sfoglia il Nostro Negozio
Dettagli Prodotto
Descrizione
Descrizione
Mankind's early attempts at spinning amounted to sending fleets of feather-coated sailboats in opposite directions off the ends of the earth, in effort to tickle the resting turtle on whose back it rested. Delegate the dizziness to your MacBook today with our Unibody 8x SATA SuperDrive (Pre-Mid 2009).
Dual-layer SATA drive. Metal mounting bracket and orange ribbon cable not included.
Note: This optical drive has a different connector than previous Apple drives.
Compatibilità
MacBook Pro 15" Unibody Late 2008 and Early 2009
2.4 GHz
2.53 GHz
2.66 GHz
2.8 GHz
2.93 GHz
MacBook Pro 17" Unibody
2.66 GHz (Early 2009)
2.8 GHz (Mid 2009)
2.93 GHz (Early 2009)
3.06 GHz (Mid 2009)
MacBook Unibody Model A1278
2 GHz
2.4 GHz
Storie di Riparazione
Avatar utente
Sondre Selnes's Story Photo #257497
Il Mio Problema
The fan on my MacBook Pro was reaching its end. It was terrible noisy ! I was in the middle of a programming project for the iPhone and making video guide for the new software, when the fan of my computer broke down. I had to stop all recording (Big Blue Yeti mic, ScreenFlow recording...).
La Mia Riparazione
The vi . . .
Avatar utente
Il Mio Problema
Old drive was becoming unreliable
La Mia Riparazione
Instructions were spot on.
Il Mio Consiglio
Tweezers are a must on this repair. The small screws are easy to remove but the bulk of the time is spent replacing them when you do not use tweezers. I used a plastic knife rather than a spudger. Worked just fine.
Avatar utente
Il Mio Problema
Fan bearing started getting noisy and then fan started to be slow/intermittent causing overheat shutdown of the MacBook.
La Mia Riparazione
Watched your video to see what I was in for. Seemed relatively straightforward. Opened up the case and got to the fan. 2 of the 3 Philips screws came out easy. One was REALLY torqu . . .
Avatar utente
Il Mio Problema
The old fan had worn out bearings which caused lots of noise and bad performance.
La Mia Riparazione
The switch went well. Took about 30 minutes because the screws were stripped. The comments were very helpful.
Il Mio Consiglio
If the screws are stripped, take a similar size flat screwdriver and put at 45 degrees into the screw so the s . . .
Avatar utente
Il Mio Problema
CPU temperatures had started to spike on my laptop (80C or higher) while doing mundane things at low percentages of CPU, and fan didn't spin up to cool the machine. Apple did diagnostics, said all was well. Temperature Gauge Pro detected a problem with fan, however, so I ordered a replacement to s . . .
Avatar utente
Il Mio Problema
Loud noises prompted me to take my Macbook Pro to the Genius Bar. They wanted to keep it for 3+ days to replace the fan, at a pretty significant cost. I happen to be blessed with a very smart teenager who cut his teeth on taking Mac's apart. Quick order on iFixit, an even faster delivery, and voi . . .
Avatar utente
Il Mio Problema
battery only lasted about an hour fully charged, and it the whole computer would rapidly overheat.
La Mia Riparazione
A bit scary. The battery went in without a hitch, but when removing the old fan, the socket ripped off of the circuit board. I ended up soldering the individual wires back on. Now it works great though! . . .
Avatar utente
Il Mio Problema
The old fan had become noisy - bearings worn out probably. (After taking it out, I could see the blades spun crooked.)
La Mia Riparazione
Pretty easy repair, only 3 internal screws. The connector is a little tricky since it's so small, you tend to think you're gonna break it. Go slowly around the edges and it'll com . . .
Avatar utente
Il Mio Problema
My fan was making a god awful sound whenever my macbook would start heating up. This had been happening ever since an unfortunate crepe experience where I managed to spill lemon-sugar syrup into my keyboard.
La Mia Riparazione
The repair was incredibly straight forward. It was a very minimal risk procedure.
Il Mio Consiglio
Be prepared . . .
Avatar utente
Il Mio Problema
The blades on the original fan had broken and was making a lot of noise when it spun up.
La Mia Riparazione
I've opened the computer many times before so the repair was a piece of cake. ~5 minutes in total.
Il Mio Consiglio
Mostra di più
