PC3-10600 8 GB RAM Chip
  • PC3-10600 8 GB RAM Chip
69,99 US$
69,99 US$
Ti invieremo un messaggio quando il prodotto sarà nuovamente disponibile.
Dettagli Prodotto
Descrizione
Descrizione
Adding RAM to your computer can provide a significant performance boost.
Please Note: the Mid 2010 21.5" iMacs (EMC 2389) & 27" iMacs (EMC 2390) with the Core i3 and the Mid 2011 27" iMacs (EMC 2429) with the Core i5 can only accept up to 4 of the 4 GB chips. This RAM will not work in these machines.
Nota
That "Warranty Void if Removed" sticker is wrong. Feel free to peel that sucker off, we'll still honor our warranty. Our RAM supplier made a mistake in printing, and we're fixing it in our next order of memory.
Compatibilità
iMac Intel 21.5" EMC 2428
2.5 GHz (Mid 2011)
2.7 GHz (Mid 2011)
2.8 GHz (Mid 2011)
iMac Intel 27" EMC 2390
2.8 GHz (Mid 2010)
2.93 GHz (Mid 2010)
3.6 GHz (Mid 2010)
iMac Intel 27" EMC 2429
3.4 GHz (Mid 2011)
Mac Mini Mid 2011
2 GHz (Quad i7)
2.3 GHz (Dual i5)
2.5 GHz (Dual i5)
2.7 GHz (Dual i7)
MacBook Pro 13" Unibody Early 2011
2.3 GHz
2.7 GHz
MacBook Pro 13" Unibody Late 2011
2.4 GHz
2.8 GHz
MacBook Pro 15" Unibody Early 2011
2 GHz
2.2 GHz
2.3 GHz
MacBook Pro 15" Unibody Late 2011
2.2 GHz
2.4 GHz
2.5 GHz
MacBook Pro 17" Unibody
2.2 GHz (Early 2011)
2.3 GHz (Early 2011)
2.4 GHz (Late 2011)
2.5 GHz (Late 2011)
Visualizza 6 altri dispositivi
Storie di Riparazione
Il Mio Problema
My hard drive went out on my late 2011 mbp but I didn’t want to spend money on a new laptop so I bought an ssd drive and I also decided to upgrade the ram. I bought a refurbished memory ram on ifixit.com because I didn’t want to spend much money plus they offer life time warranty on it and let m . . .
Il Mio Problema
Upgrade RAM
La Mia Riparazione
SIMPLE
Il Mio Consiglio
Follow the instructions and make sure you have the necessary tools
Il Mio Problema
Just not enough ram for my taste
La Mia Riparazione
amazing
Il Mio Consiglio
Replacing the ram in the earlier model macs can be the easiest of fixes. It really did only take me 30 seconds to replace the ram.
Il Mio Problema
Super slow beachballing crashing
La Mia Riparazione
Incredibly easy to do ---- changed out the two 2GB RAM for two 8GB RAM in under 15 min.!
Il Mio Consiglio
"Below Average" now overall on EtreCheck instead of "Failed" b/c back-up disk is too small. Can't do anything about that with this old machine. Very happy I can keep using it . . .
Il Mio Problema
Need for speed...I typically have 5+ windows open all the time so speed suffers and the 8GB the laptop came with was slowing down. The price from iFixit was good, warranty great, and the directions simple.
La Mia Riparazione
Almost without a hitch. I have oversized fingers (size 13.5 wedding band) so it took a little e . . .
Il Mio Problema
Just wanted to max-out the RAM
La Mia Riparazione
No problems
Il Mio Consiglio
Keep up with the screws, make sure you reinstall the correct screws in the correct holes.
Il Mio Problema
My MacBook was getting too slow.
La Mia Riparazione
It was such an easy task, finished it in less than a min after opening it up.
Il Mio Consiglio
Big improvement than what I was experiencing before.
Il Mio Problema
J'avais un problème avec la capacité de la mémoire vive de mon MacBook Pro. Je suis passé de 4G à 16G de mémoire vive. Il réagit très bien.
Jean-Robert Grenier
La Mia Riparazione
Très bien
Il Mio Consiglio
Tout était très bien expliqué.
Il Mio Problema
Just a slow processing computer ever since yosemite. 4 mb ram is not enough and 500gb hard drive not enough space.
La Mia Riparazione
Easy, I figured while had it open a new SSDHD was nessery along with 16gb ram. With the great instructions, I had both done in about 1/2 hour once i started.
Il Mio Consiglio
Read all of the instructi . . .
Il Mio Problema
The computer was incredibly slow and was running out of free space.
La Mia Riparazione
The repair was quite simple and intuitive. According to the comments, I didn't disconnect all the wires and the repair was still really easy.
Il Mio Consiglio
You can add thin pieces of foam to reduce HD vibrations.
Mostra di più
