PC2-5300 1 GB RAM Chip
  • PC2-5300 1 GB RAM Chip
9,99 US$
9,99 US$
Ti invieremo un messaggio quando il prodotto sarà nuovamente disponibile.
Dettagli Prodotto
Descrizione
Descrizione
Adding RAM to your computer can provide a significant performance boost. Install in matched pairs for increased performance.
PowerBook G4 Aluminum 1.67 GHz high-resolution machines originally shipped with PC2-4200 RAM, but this chip can be installed instead of PC2-4200 RAM and is fully compatible.
Nota
That "Warranty Void if Removed" sticker is wrong. Feel free to peel that sucker off, we'll still honor our warranty. Our RAM supplier made a mistake in printing, and we're fixing it in our next order of memory.
Compatibilità
iMac Intel 17"
1.83 GHz (EMC No. 2104)
1.83 GHz (EMC No. 2110)
1.83 GHz (EMC No. 2124)
2 GHz
2.16 GHz
iMac Intel 20" EMC 2105 and 2118
2 GHz
2.16 GHz
2.33 GHz
iMac Intel 20" EMC 2133 and 2210
2 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2133)
iMac Intel 24" EMC 2111
2.16 GHz
2.33 GHz
iMac Intel 24" EMC 2134 and 2211
2.4 GHz (EMC No. 2134)
2.8 GHz (EMC No. 2134)
Mac Mini Model A1176
1.5 GHz (Core Solo)
1.66 GHz (Core Duo, Early 2006)
1.66 GHz (Core Duo, Late 2006)
1.83 GHz (Core 2 Duo, Mid 2007)
1.83 GHz (Core Duo, Late 2006)
2 GHz (Core 2 Duo)
MacBook Core 2 Duo
1.83 GHz
2 GHz (Early 2009)
2 GHz (Late 2006)
2 GHz (Mid 2007)
2 GHz (Santa Rosa)
2.1 GHz (Penryn)
2.16 GHz
2.2 GHz (Santa Rosa)
2.4 GHz (Penryn)
MacBook Core Duo
1.83 GHz
2 GHz
MacBook Pro 15" Core 2 Duo Model A1211
2.16 GHz
2.33 GHz
MacBook Pro 15" Core 2 Duo Models A1226 and A1260
2.4 GHz (Penryn)
2.4 GHz (Santa Rosa)
2.5 GHz (Penryn)
2.6 GHz (Penryn)
2.6 GHz (Santa Rosa)
MacBook Pro 15" Core Duo Model A1150
1.83 GHz
2 GHz
2.16 GHz
MacBook Pro 17" Models A1151 A1212 A1229 and A1261
2.16 GHz (Core Duo)
2.33 GHz (Core 2 Duo)
2.5 GHz (Penryn)
2.6 GHz (Penryn)
Visualizza 9 altri dispositivi
Storie di Riparazione
Il Mio Problema
My 20" iMac and it is old, was running slow with lots of the famous spinning Beach Ball o' Doom
La Mia Riparazione
I was able to replace the RAM chip with 2-PC2-5300 2 GB RAM Chips and it took me all of about 15 mins. If I had known about this site and all the great guides I would have done it a lot sooner.
Il Mio Consiglio
Don't be afr . . .
Il Mio Problema
Computer was crawling, freezing up, not enough Gigs to update software.
La Mia Riparazione
So simple. A five minute fix with my ordinary Phillips screwdriver just saved me $1000 bucks!
Thanks for the tips, ifixit!
Il Mio Consiglio
Just make sure you have the right model number before you order parts.
Il Mio Problema
Old Macbook didn't have enough RAM (1GB) to quickly access the the Internet and process applications.
La Mia Riparazione
VERY EASY - The new RAM (2GB Total) arrived on-time and was quick to install following the IFIXIT instructions with pics. Took me less than 15 minutes!
Il Mio Consiglio
My tips are:
1. Make sure when you remove the ex . . .
Il Mio Problema
My Macbook only had 1GB of Memory which was slowing down Internet and processing speed and IFIXIT had such a GREAT price for adding an additional 1GB and provided easy instructions with pictures for me to DIY.
La Mia Riparazione
It was very straightforward with easy instructions and pictures. It was also beneficial to . . .
Il Mio Problema
The problem: I wanted to upgrade from 1GB of RAM to 2GB.
I purchased my MacBook1,1 in 2006, with 1 GB of RAM. The most recent OS installed was 10.2. That OS is pretty behind the times; it doesn't recognize my iPhone, and none of my browsers can be considered secure any more. It was time to upgrade . . .
Il Mio Problema
No enough default RAM (512MB only).
La Mia Riparazione
Very well.
Il Mio Consiglio
No.
Il Mio Problema
1GB -> 2GB Upgrade
La Mia Riparazione
Repair went well. Very Easy following iFixit directions
Il Mio Consiglio
Having and using the correct tools makes the job go smoothly.
Il Mio Problema
Simply to slow
La Mia Riparazione
It went just fine!
Il Mio Consiglio
I used the guide
Il Mio Problema
My 2006 Mac mini was still running tiger os 10.4.11. Unable to use many newer applications, update web browser, sign up for nest account for my newly installed nest, etc because computer was too slow. Also it would stall out constantly, freeze up and quit unexpectedly. Needed more memory and new OS. . . .
Il Mio Problema
to little rams to upgrade the computer to OS-X lion
La Mia Riparazione
Installing a new 2 GB RAM chip i addition to the existing 1 GB RAM chip using the guide went smooth, to the MacBook Pro 15 model 1211
Il Mio Consiglio
read about possibilities for upgrading.
Follow the instruction
Mostra di più
