Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
MacBook Unibody (A1342) Trackpad
  • MacBook Unibody (A1342) Trackpad
  • 360°
360
74,99 USD
74,99 USD
Ti invieremo un messaggio quando il prodotto sarà nuovamente disponibile.
Nintendo Switch Kits
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
Dettagli Prodotto
Descrizione
Descrizione
Replace a damaged trackpad and restore the touch sensitivity of your MacBook Unibody (Model A1342) laptop.
A worn out trackpad may have cosmetic scratches or a cracked surface causing it to malfunction. In addition, an aging trackpad may become unresponsive making your laptop difficult to control.
Compatibilità
Compatibilità
  • MacBook 13" Unibody A1342 Late 2009 to Mid 2010
Specifiche
Specifiche
Part #:
922-9551, 922-9175, 661-9551
Compatibilità
MacBook Unibody A1342
EMC 2350 2.26 GHz
EMC 2395 2.4 GHz
Storie di Riparazione
Avatar utente
Il Mio Problema
The track pad went from not clicking to moving around sporadically while you tried to click on anything.
La Mia Riparazione
It was very simple when following the directions.
Il Mio Consiglio
After installing the track pad dont screw on the bottom immediately. Turn on the computer and check the 'clickage'. You might have to tighten or lo . . .
Avatar utente
Il Mio Problema
I helped my niece purchase her first used computer. When it arrived the trackpad wouldn't click. Instead of sending it back for a refund and realizing we would lose the shipping to and from and then not have a computer, I decided to go ahead and replace it myself.
La Mia Riparazione
Part was delivered in a timely manne . . .
Avatar utente
Il Mio Problema
Using ifixit repair guide I bought and installed a new trackpad.
La Mia Riparazione
Following the guide It was easy and problem solver in 15 minutes.
Il Mio Consiglio
Ifixit, The right guide at The right place with the right parts!
Avatar utente
Il Mio Problema
Old and dead trackpad.
La Mia Riparazione
Only took ten minutes!
Il Mio Consiglio
Works like new! Took me ten minutes to replace the trackpad.
Will order again from iFixit as they use quality parts.
Avatar utente
Il Mio Problema
My white unibody macbook was having problems with the trackpad. After days of searching the internet, trying software fixes, cleaning, checking battery, etc, nothing worked. I finally decided to go for it and buy a new replacement Trackpad with screws, the #00 Phillips Screwdriver, and the Y1 Tri- . . .
Avatar utente
Il Mio Problema
Trackpad clicker didn't work
La Mia Riparazione
The instructions were very clear and replacement went easy.
Il Mio Consiglio
After installing the new trackpad the clicker still didn't work. I took it apart and noticed an adjustment screw that actuates the detent. I increased it and then it worked great. I didn't bother to try the old tr . . .
Avatar utente
Il Mio Problema
The battery swelled in the middle so much that it pushed the track pad up our of the computer.
La Mia Riparazione
Trackpad replacement seemed at first not to work, new pad was also out of alignment, but shifting the strips that hold it in slightly solved the problem and the track pad aligned. Worked perfectly. Putting . . .
Avatar utente
Il Mio Problema
My trackpad lost it's clicking ability
La Mia Riparazione
Replace with a brand new trackpad bought from www.ifixit.com
Il Mio Consiglio
Please don't rush with any of your repairs. That's what I got from my past and present experiences.
Avatar utente
Il Mio Problema
My son dropped his phone onto his trackpad and chipped the corner of it.
La Mia Riparazione
We received the part and tool within a couple of days. I reviewed the online repair process and ten minutes later we were up and running again.
Il Mio Consiglio
I would definitely use Ifixit again and recommend the online tutorials. They are ea . . .
Avatar utente
Il Mio Problema
My MacBook track pad was acting up. Unable to click, not very responsive to touch.
La Mia Riparazione
The repair process went smooth thanks for the useful detailed guide and all the tools and accessories provided by iFixit.com.
Il Mio Consiglio
If the track pad just not clickable (or having trouble clicking), just need to readjust the . . .
Mostra di più
