Il Mio Problema
A friend of mine needed a laptop - and is currently unemployed. My downstairs neighbor had a MacBook, that appeared to work, but the left hinge was broken and the display was tenuous. Opening and closing it almost tore it all to shreds. I offered to fix it for her if she sprang for the parts...
La Mia Riparazione
I got down with my headlamp, lots of little ziploc bags, a pad of paper and a sharpee. As I took apart the laptop at each stage, I taped the pieces to a numbered sheet of paper or placed them in a labeled ziploc. I got all the way in, when I realized all the the threads on the back display cover were broken off….
I had to set it aside, order the other part, and wait. When the back display came, I pulled it all out, finished everything, and then the display did not turn on :(
Back in I went, realized I had not properly secured the video cable, fixed it, closed it, and it all worked!!!
ONLY 5 hours…..
Il Mio Consiglio
Take apart the unit before ordering parts, like that you can be sure you have all the parts you need she you order them!!
Il Mio Problema
La Mia Riparazione
I got . . .
