Aggiusta la tua roba
Diritto alla Riparazione
Store
Parts Mac MacBook Pro Display Components
Store
Grab a toolkit for your MacBook Pro model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Non sai qual è il tuo modello? ID del tuo Mac
MacBook Pro 17" (Model A1151/A1212) Display Inverter
Replace a malfunctioning inverter board in a 17" MacBook Pro. A bad inverter can cause a dead backlight.
69,99 USD
MacBook Pro 15" (Model A1150) Antenna Cover
This antenna cover houses the airport antenna assembly compatible with the Model A1150 EMC 2101 15 inch MacBook Pro laptop. Part #922-7279.
9,99 USD
MacBook Pro 17" (Model A1212) Clutch Cover
Replace a faulty, cracked or broken LCD hinge clutch cover on your MacBook Pro 17".
19,99 USD
MacBook Pro 15" (Models A1150/A1211) Rear Display Bezel
Replace a damaged bezel without the cost of a new LCD
Da 59,99 USD
MacBook Pro 17" (Model A1212) Antenna Cover
Replace an Antenna Cover compatible with the A1212 model 17" MacBook Pro laptop. This part houses the AirPort antenna cable assembly within the clutch cover.
19,99 USD
MacBook Pro 15" (Models A1211/A1226) Airport Antenna Cables
Replace the antenna cables and the assembly that rests inside the antenna cover compatible with the A1211 or A1226 model 15 inch MacBook Pro laptop.
19,99 USD
MacBook Pro 15" (Models A1226/A1260) LED Driver Board
LED Driver Board controls the LED backlight.
44,99 USD
MacBook Pro 15" (Models A1226/A1260) Inverter/iSight Cable
14,99 USD
13" Unibody LVDS Display Cable
Replace a broken or damaged LCDS display cable in your laptop.
34,99 USD
MacBook Pro 15" (Model A1260) AirPort Antenna Cables
Replace the antenna cables and the assembly that rests inside the antenna cover compatible with the A1260 model Early 2008 15 inch MacBook Pro laptop.
14,99 USD
Visualizzazione prodotti 1 - 10 di 19
Informazioni Dispositivo
Catering to the working professional, the MacBook Pro is aptly named. With powerful processor and graphics capabilities, these Apple machines are great for either the professional or aspiring creative genius.
We sell dozens of MacBook Pro upgrades and repair parts. It's easy, fast, and safe to max out your machine! Two RAM slots allow for an easy memory boost. Need more storage? Drop in a larger-capacity 500 GB 7200 RPM 9.5mm SATA hard drive for some much-needed space as well as speed. An 85-watt MagSafe adapter will keep your machine juiced through even the most power demanding processes.
Select your version above for parts and assistance!
