Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
MacBook Pro 17" (Model A1261 Hi-Res) LCD LED Panel
  • MacBook Pro 17" (Model A1261 Hi-Res) LCD LED Panel
219,99 USD
219,99 USD
Ti invieremo un messaggio quando il prodotto sarà nuovamente disponibile.
Kit per Nintendo Switch
Una soluzione rapida per tornare in gioco
Acquista Kit per Switch
Dettagli Prodotto
Descrizione
Descrizione
Replace a damaged or malfunctioning 17" 1920 x 1200 LCD panel in your MacBook Pro 17" (Model A1261 Hi-Res) laptop.
This LCD panel can restore dead pixels, fix color bleeding, and eliminate lines in your display image as well as restore a dim or dead backlight.
Compatibilità
Compatibilità
  • 2.5 or 2.6 GHz (Model A1261) 17" MacBook Pros with 1920x1200 resolution
Specifiche
Specifiche
Size:
17"
Resolution:
1920 x 1200
Compatibilità
MacBook Pro 17" Models A1151 A1212 A1229 and A1261
A1261 (EMC 2199) 2.5 GHz (Penryn)
A1261 (EMC 2199) 2.6 GHz (Penryn)
Storie di Riparazione
Avatar utente
Il Mio Problema
LCD was bad on a Macbook Pro A1261, ordered new screen.
La Mia Riparazione
Took everything apart only to realize I had ordered the wrong screen. Take note technicians, check your connectors on new parts before breaking everything down. And read everything about the part you are ordering carefully.
Il Mio Consiglio
iFixit team respond . . .
Avatar utente
Il Mio Problema
in quick succession I broke the LCD on the 17" Macbook Pro due to sloppy handling, and I shattered the glass front on my iPhone 5.
Both were not yet at the end of their life/usefulness so I decided to fix both myself.
La Mia Riparazione
things went pretty well. Finished both repairs in about 3 hours (while watching . . .
Avatar utente
Il Mio Problema
My 1 year old son had smashed my MacBook Pro screen and it was damaged for more then a year. I inquired at the local Apple Store and was shocked to know that the LED display would cost me around 1000$, it was so expensive that I thought I would never be able to repair it, until ifixit stepped in my . . .
Avatar utente
Il Mio Problema
Broken LCD on my macbook pro
La Mia Riparazione
Ordered part to fix. But it was damaged:( so i called got a replacement. Great CS by the way. Well.. I got ancy and started to take apart the laptop and found out that i ordered the wrong part.. Called back and the 1st replacement was already sent. So i ordered the right . . .
Mostra di più
