MacBook Pro 17" (Non-Unibody) Logic Boards
Grab a toolkit for your MacBook Pro 17" (Non-Unibody) model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Scegli il tuo modello di MacBook Pro 17" (Non-Unibody):
Parti che funzionano con MacBook Pro 17" (Non-Unibody):
MacBook Pro 17" (Model A1151) 2.16 GHz Logic Board
Replace a 2.16 GHz Core Duo logic board (motherboard) compatible with the model A1151 MacBook Pro 17" laptop. Fix processing issues like unexpected shutdowns, reboots, or...
MacBook Pro 17" (Model A1212) 2.33 GHz Logic Board
Replace a 2.33 GHz Core 2 Duo logic board (motherboard) compatible with the model A1212 MacBook Pro 17" laptop. Fix processing issues like unexpected shutdowns, reboots, ...
MacBook Pro 17" (Model A1229) 2.4 GHz Logic Board
Replace a 2.4 GHz Core 2 Duo logic board (motherboard) compatible with the model A1229 MacBook Pro 17" laptop. Fix processing issues like unexpected shutdowns, reboots, o...
MacBook Pro 17" (Model A1261) 2.5 GHz Logic Board
Replace a 2.5 GHz Core 2 Duo logic board (motherboard) compatible with the model A1261 MacBook Pro 17" laptop. Included Ports: DVI Video Out, 1000BaseT Ethernet, Firewire...
MacBook Pro 17" (Model A1261) 2.6 GHz Logic Board
Replace a 2.6 GHz Core 2 Duo logic board (motherboard) compatible with the model A1261 MacBook Pro 17" laptop. Fix processing issues like unexpected shutdowns, reboots, o...
Informazioni Dispositivo
The MacBook Pro 17" replaced the Aluminum 17" as Apple's pro machine and features Intel processors and a large widescreen display. The cases of the MacBook Pro 17" Models A1151, A1212, A1229, and A1261 are composed of aluminum, just like the PowerBook G4 before it, but the MacBook Pro 17" includes a built-in web camera called iSight, and a MagSafe power connector.
The most common repairs with the Non-Unibody model 17" MacBook Pro laptops are replacing a dead battery, replacing a malfunctioning fan, and upgrading the hard drive or RAM.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 17" repair guides for step-by-step instructions on how to make the fix.
